Question about Apple iPod nano
SCREEN SHOWS NOW PLAYING MENU BUT NOTHING IS PLAYING. IT WON'T CUT OFF AND THE WHEEL DOES NOT RESPOND.THE BUTTON IS NOT ON HOLD.I TRIED TO RESET IT AND THAT DID NOT WORK. I GET NO RESPONSE FROM THE WHEEL.
  • Hey Man Apr 17, 2008
    Exactly the same thing has happened to my ipod nano. I am going to look at getting it fixed or buy a new one. Tried to reboot. It was on lock for a long time wheel won't turn, everything else lights up.
  • HOOKING BULL May 11, 2010
    I moved the lock switch into lock position,waited a few seconds. I moved the switch back to unlock position, then reset the ipod.
  • Apple Master
  • 13,433 Answers
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore…
www.apple.com/support/ipod/five_rs/
Posted on Apr 19, 2008
I've removed the cable from iPod to soon from a sync .... now ipod has frozen and nothing is working on iTunes at all
You need to Perform a Hard Reset on iPod Classic..To perform an iPod hard reset , start by toggling the hold switch from off to hold, then back off again. Press and hold down the Center button (middle of click wheel) and the Menu button. Continue to hold these buttons down until you see the Apple logo on the iPod screen (approximately 6-8 seconds).
If the hard reset doesn't work the first time, try it again a couple more times. Sometimes it works the second or third time around.
If the iPod hard reset is still not working, try connecting your iPod to a power source, or computer, and then doing the hard reset.
*For older iPod models, you may need to hold down the Play/Pause button and menu button, rather than the Center button and Menu button...Take care..
Sep 10, 2017 | The Audio Players & Recorders
Instruction manual
Which model ipod ??
In keeping with Apple's goal to make user-friendly, streamlined products, the designers of the iPod built in easy-to-use reset functions into each iPod model.
Resetting the iPod is similar to rebooting a computer as all songs and data stored on the device stay there, and only temporary information (such as which song is playing) gets reset.
Follow these steps to reset an iPod.
Toggle the "Hold" switch to the "On" position, then "Off."
The "Hold" switch is the small sliding switch on the top of the iPod.
Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle.
Hold the "Menu" and "Center" buttons.
Press the 2 buttons at the same time for between 8 and 10 seconds.
Your screen will go blank and then boot up with a dark Apple icon.
The icon eventually turns bright and brings you back to your main menu once the reset is complete.
Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process.
Scroll Wheel and Touch Wheel iPods
Move the "Hold" switch from "On" to "Off."
Press the "Play/Pause" button and the "Menu" button at the same time.
Press both buttons together for approximately 6 to 8 seconds.
This initiates the self-running reset process.
Make sure the reset was successful.
If problems persist you may need to perform the reset process once again.
iPod Nano
Move the on-off switch to the "Off" position that shows the green strip.
Leave the iPod Nano in this position for 5 seconds.
Move the switch back to the "On" position.
Use your iPod Nano to make sure the reset worked properly and all your music is intact.
Aug 06, 2013 | Starlite Nextplay Fashion iPod Docking...
How do i fix my ipod
Toggle the "Hold" switch to the "On" position, then "Off." The "Hold" switch is the small sliding switch on the top of the iPod. Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle. Hold the "Menu" and "Center" buttons. Press the 2 buttons at the same time for between 8 and 10 seconds. Your screen will go blank and then boot up with a dark Apple icon. The icon eventually turns bright and brings you back to your main menu once the reset is complete. Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process. b> Scroll Wheel and Touch Wheel iPods Move the "Hold" switch from "On" to "Off." Press the "Play/Pause" button and the "Menu" button at the same time. Press both buttons together for approximately 6 to 8 seconds. This initiates the self-running reset process. Make sure the reset was successful. If problems persist you may need to perform the reset process once again. b> iPod Nano Move the on-off switch to the "Off" position that shows the green strip. Leave the iPod Nano in this position for 5 seconds. Move the switch back to the "On" position. Use your iPod Nano to make sure the reset worked properly and all your music is intact.
iPod into Diagnostic Mode
http://www.methodshop.com/gadgets/ipodsupport/diagnosticmode/index.shtml
Apr 18, 2013 | Apple Audio Players & Recorders
My nano 4g will only respond to a shake, nothing else
have you tried to reset the ipod yet? I've included a step by step below just in case you are unfamiliar with reseting your ipod. Many user are LoL ;)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
Apr 26, 2009 | Apple iPod nano
PS3 won't even show the menu screen
I suggest trying to reset the system by turing the system off first. ( Do not cut the power switch off in the back of the system). Then hold the on button for 3 beeps. See what happens.
Mar 18, 2009 | Sony Playstation 3 (PS3) Console
CLICK WHEEL IS NOT RESPONDING
Hi!
Please try resetting the ipod by pressing the center and play button on your ipod until it displays apple logo. Also try restoring it to factory settings by seeing this link from apple---
Restoring apple ipod
Please rate this solution if you find this solution helpful.
Thanks
Rylee
Feb 08, 2009 | Apple iPod classic MP3 Player
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
Apple ipod
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
21 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
