Question about X2Gen MG19MY 19" LCD Monitor
X2Gen 19 inch LCD Monitor problem
X2Gen 19 inch lcd monitor does not power on. The power button is on and lit up but nothing on the screen. One of the expert's advice was is to hit input button on the side of the monitor. Where exactly is the button and will it fix the problem?
    Sergeant:
  • 406 Answers
Its the problem of the main display board. Not the SMPS. There will be another board inside. You have to replace the board or If some body may fix if you have spare parts of the board.
Posted on Apr 11, 2008
I have x2Gen 19" LCD Monitor. I hooked up the
More likely to be the fuse for the backlight inverter circuits rated at 3.5 or 4Amps. It is PICO fuse.
The transistors that drive the inverter transformers may have been damaged, should check them out before installin a new fuse. In the mean time you can use 1 to 2 Ohms 1/2 Metal Oxide (MOX) resistor in place of the fuse, if the resistor overheatand open up then you have shorts circuits.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 19, 2010 | X2Gen MG19MY 19" LCD Monitor
Monitor does power up but no picture??
heck342, Your monitor may have the common "black screen of death" that will occur to ANY AND ALL cold cathode-fluorescent-lamp, back-lit, lcd monitors sometime during their lifetime. You will need to do a lot of reading in my fixya profile and those of "buddymc" , "budmrtn" and then you will understand what you will or will not do with your unit. I'll even bet you haven't been to YOUTUBE to view any DIY repair videos yet! Come back here for more info after you do a little research on the WEB, and can tell us tech's that you know the difference between a "black screen" and a "blank n black screen" monitor. Remember this, your CCFL back-lit lcd unit" design and principle of operation isn't any different than any other brand. Have you done the "flashlight test" that every CCFL back-lit lcd monitor owner should know how to perform and interpret the resulting info when black screen of death occurs? Bye for now. 12fixlouie
Jun 13, 2010 | X2Gen MG19MY 19" LCD Monitor
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
X2gen 19 inch monitor wont power on
Had the same problem with mine. First you need a volt meter (radio shack about $15). check the push in connector and make sure it has coming from it.
Place you meter on DCV for DC voltage, Then place one lead in the end of the plug in the hole. (will not fit all the way so will need to hold it there, Put the other lead on the shiny part of the plug. If you get a reading of 12 volts +/- 1 volt your good. Depending on which lead is were you may get a minus reading this is fine as if you switch your leads around it will go positive. you must have the cord plugged into the wall to do this test. You will not get shocked or anything as 12v is not enough to hurt you.
If you have the 12 volts the problem is in the monitor on the male plug or on the board. this takes more to fix and must take the back off the monitor and fix the connection or replace. I did this to mine and it is working right now.
Apr 10, 2009 | X2Gen MG19MY 19" LCD Monitor
X2gen 19 inch wont turn on.
my Acer Orbicam that takes picters and vidios stopd working just like that and i dident do enithing rong it just stopd working please can someone help me
May 30, 2008 | X2Gen MG19MY 19" LCD Monitor
19 inch wide Tftlcd monitor FV926w comes on then goes black
There is power problem in your monitor maybe in the high voltage section. maybe there is capacitor that leaky that cannot hold the power. Need to bring this to the expert technician to fix it
Apr 15, 2008 | X2Gen MG19MY 19" LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Lost my cd need driver
No drivers are needed for the monitor.
Oct 12, 2007 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
166 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
