Computers & Internet Logo
Posted on Jun 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to load a frame in my html page in the event of submitting the value of one of the radio buttons in the list.how can i do this by using html and javascript?
Anonymous
Level 2:
  • Expert 249 Answers
  • Posted on Jun 11, 2010
Anonymous
Expert
Level 2:
Answers
249
Questions
0
Helped
69679
Points
680
Hi!
Download JQuery and use that. JQuery will help you with a lot of problems and ease your programming with javascript.
I hope this helps.
How do I get the manual for sylvania SCR1388B
Curtis International which made the Sylvania clock radio no longer has any support for its legacy electronics. ManualsLib has manuals for several Sylvania clock radio models here: https://www.manualslib.com/brand/sylvania/clock-radio.html . They have a link for the SCR1388B, https://www.manualslib.com/manual/944856/Sylvania.html . This document doesn't list the SCR1388B on the cover page. However, the two clock radios are probably similar enough that the manual will help you use your clock radio. If this manual doesn't provide enough details, please check some of the other manuals listed at the first link above.
I hope this helps. ManualsLib does provide an option to get the manual as a PDF. See the Download button near the top of the page. You will need to go through some CAPTCHA checks to download the file as a PDF.
Hp laserjet p3005 68.1 error coming
The actual error says that the hard drive is bad. I bet that you don't have a hard drive on your printer, so read on...
From the manual
NVRAM initialization
CAUTION Initializing the NVRAM resets the serial number, the event log, the page counts, and
the EIO card (initializing the NVRAM resets SERVICEmenu values to factory defaults). Use the
service menu to restore the serial number and page counts. Also reconfigure any computers that
print to this device so that the computers can recognize the device. Initialize the NVRAM only
when absolutely necessary. In most situations, use a cold reset rather than a NVRAM initialization
to reset device settings (this will retain the values in the SERVICEmenu).
NOTE Before performing a NVRAM initialization, print a menu map and a configuration page
. Use the information on the configuration page to reset
any customer-set device configuration values that the NVRAM initialization procedure changes.
Take special note of the total page count, maintenance count, and the serial number.
1. Remove any installed accessories.
2. Turn the device off.
3. Turn the device on. When the memory count begins, press and hold the button. Continue
holding down the button until all three device control-panel lights flash once and then remain
on. This might take up to 10 seconds.
4. Press the button.
5. Press the Menubutton. The display should show SKIP DISK LOAD.
6. Press the button until NVRAM INITis highlighted.
7. Press . The device initializes NVRAM and then continues the power-on sequ
I want see the manual book and how to get cd pc suite?
  • Documents
    • Requires Acrobat Reader
    • Manual Owner Manual
    • GET --> function fncCSFileDown(docId,fileName,originalName,scCategoryName) { var form = document.getElementById('formDown'); document.getElementById('DOC_ID').value = docId; document.getElementById('FILE_NAME').value = fileName; document.getElementById('ORIGINAL_NAME_b1_a1').value = originalName; document.getElementById('TC').value = 'DwnCmd'; form.target="pdf_down"; form.action="/lgecs.downloadFile.ldwf"; var s=s_gi(s_account); //var s=s_gi('lgeusdev'); s.linkTrackVars='eVar11,events'; s.linkTrackEvents='event4'; s.events='event4'; s.eVar11=fileName; s.tl(this,'d', scCategoryName); form.submit(); } Downloads
  • PDF reader is required to view the manual
2answers
In my ebay pictures are not showing, but show in the listing
For future reference, if you find that you have deleted the images from an active listing that was posted through Auctiva, provided that the items have not received bids and have more than 12 hours left, you should be able to restore the images in the description via the following process:
1) Locate your listing in your Saved Listings folder, make any necessary changes, and save.
2) Click the " icon to the right of the item on your "Saved Listings" page
3) Select All and copy the html in the popup window.
4) Locate the item on eBay and click the "Revise Item" button.
5) Scroll down to the "Description" section and then click the "HTML" tab above the description editor.
6) Delete the existing description HTML, paste the copied HTML in its place, and save your changes.
In the event the item in question has already received bids, you could potentially add the missing images to the bottom of the description using the "Add images" tool on the Active Listings page within your account.
If you need any further assistance with this situation, please feel free to contact our customer support team using the web form on the following page of our site: http://www.auctiva.com/help/requesthelp.aspx
`kf750 pc suite
  • Documents
Working on project to develop online movieshop management
you can embed 'google search' engine to your website.
The basic technique involved here is to be able to manipulate one of the variables handed to the Google search engine, a variable called sitesearch. Set it to a null value and you're searching the entire World Wide Web, but set it to a specific domain and it's constrained exactly as if you had typed in the Google special notation site:domain.
In addition to that, you need an input field and a submit button. Put them all together and here's the minimalist Google search form that lets the user alternate between just your site (well, in this case just my site) or the entire Web:
<form method="get" action="http://www.google.com/search">
<input type="text" name="q" size="31"
maxlength="255" value="" />
<input type="submit" value="Google Search" />
<input type="radio" name="sitesearch" value="" />
The Web
value="askdavetaylor.com" checked /> Ask Dave Taylor<br />
There are some additional tweaks we can apply to make it a bit more
fancy, including changing the radio buttons to a single check box, and
<div style="border:1px solid black;padding:4px;width:20em;">
<table border="0" cellpadding="0">
<tr><td>
<input type="text" name="q" size="25"
<input type="submit" value="Google Search" /></td></tr>
<tr><td align="center" style="font-size:75%">
<input type="checkbox" name="sitesearch"
value="askdavetaylor.com" checked /> only search Ask Dave Taylor<br />
</td></tr></table>
</div>
</form>
aligning things a bit more nicely using a table and some simple CSS:
</form>
Display text from one page to another page
you can specifying your target frame using TARGET tag. see this site
But i suggest you don't use framed site, because it's not Search engine friendly. Search engine only know each of your html page, not framed page. When people click there (except they land the home site), they won't see your menus
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
