Question about Samsung 215TW SyncMaster 21" LCD Monitor
Dvi input cannot switch to pc on dvi connection
Have you setup the ext mon at the desktop?
Just let me know .
Posted on Apr 12, 2008
Connect desktop pc to my samsung big screen tv?
match the display outputs on the back of the computer to the inputs on the TV. ..use Appropriate cable and switch TV Input to that type
No matching input ??
Search amazon for converter cable
DVI to HDMI usually work
VGA to HDMI can be problematic and not work
Amazon com DVI to HDMI
Nov 15, 2016 | Samsung Televison & Video
PC DVI-D to Mitsubshi DVI-I no signal
have you set the dvi out to 720i as any higher the tv will not read it as a signal. you will need to verify it in properties windows will set it at 1080i. you need to change it.
Mar 08, 2014 | Mitsubishi Televison & Video
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
How do i connect my z5610 to my hd tv there is no hdmi or vga output on the pc
> no HDMI or VGA output
Every PC has either one DVI or one VGA output.
Does your z5610 have a DVI input? If so, connect the DVI-output to the DVI-input.
Or, add-in another video-card that does have HDMI output, and connect HDMI-output to HDMI-input.
Mar 06, 2011 | Computers & Internet
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no...
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
May 22, 2009 | Computers & Internet
I need help setting up the DVI input.
There are two ways to do this.
First and simplest is to simply shutdown the pc, disconnect the analog from the back of your PC and connect the DVI cable to the PC and monitor. When you turn it back on the PC will detect and switch to the DVI.
Second, and better to compare. Connect both sets of cables and go into your display settings, then select advanced options. You should see a GeForce tab in the advanced menu. On that tab there is a multi monitor display setup. Set it to mirror to both screens and apply.
Once it's set switching inputs on the monitor SHOULD work. The problem that makes it a "should" is that both the monitor and the video card have the ablility to sense a connection. So, even with mirroring setup you may have to use the first method as you can't have both connected and operational at the same time.
Give these a try, if you're not sure how to get into the display settings, comment back here with your windows version and I will give you a step by step
Chris
May 02, 2009 | ViewSonic VX924 19" LCD Monitor
Dvi input for watching tv
the DVI input must be HDCP compatible in order for HDMI to work. It's a DRM encryption protocol. Condolences. Blame hollywood for it. The monitor model is too old to have had HDCP support built in to the DVI input.
Jul 30, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Samsung 215TW SyncMaster 21" LCD Monitor Logo
85 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
