Question about Tomtom GPS
Problem with Tom Tom model GO 4D00.001 It will not go on when switch is pushed on
Gets hot and burns fuse in powew cord
Instructiuni de folosire
Posted on Jun 09, 2011
Tom tom wont turn on
Test your Power Cable for Voltage Out. If it is working properly, then your TOM TOM bit the dust but I am thinking that you are out of Power and will not turn back on unless you get her charged up.
If it is charged up, then PUSH and HOLD the POWER BUTTON for 30 Seconds and this is how you RESET the GPS.
If resetting does not work, and you have Power. Time to get a new GPS. Sorry
Mar 01, 2014 | Pantech Ease P2020 AT&T
We have a household extension cord connected to our battery, starter and a push-button near the stearing column. Dead as a door nail. But we finally found the connectors to the push buttion were hot...
Hi, I would like to help you, but I cannot tell from what you have said what is connected where. Do you have a big battery cable going from the battery positive to the big terminal on the starter solenoid? Do you then also have a wire from the battery positive to the toggle switch and a another wire from the toggle switch to the small start terminal on the starter solenoid? I don't understand why you are connecting anything to the negative terminal, as that is not necessary.
Jul 14, 2011 | 1985 Toyota Tercel
My tom tom keeps switching off as tho out of power even tho plugged in. the charger gets extremely hot as does the wire, any suggestions? it is about 3 years old
You need to plug your TOM TOM into a PC with Internet connection and go to the tomtom web site:
You will need a usb cable that has the "mini" usb standard connector that plugs into the TOM TOM unit. It should update automatically, but you will need a TomTom Home account (free) created. Then you can download the latest updates that should clear up the power issues. Otherwise, get a new power cord as they do wear out with daily use. -Greg
Sep 13, 2009 | Tomtom One Europe v2 GPS Receiver
No heat in dryer model # 96591420
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 31, 2009 | Kenmore Dryers
My iron powers on but don't get hot.
first of all check the male ac adaptor cord, maybe an open wire only cause by pulling and pushing it. if the ac cord is good then the filament may checked maybe it burn--out already
Jul 31, 2009 | Conair Dry 'N Straight Hair Dryer and...
My Kenmore electric dryer won't start... I just ran it and it ran fine. Went to start a new load and it wouldn't work. Checked breaker, plug and door switch; everything seems okay
eazy first.need 220 if got,door switch it wiil click when check where cord attaches.then the thermoal fuse.if has back panel or no same info.i call them missiles or flying saucers[thats what they look like].there white small have two wires to them.if you put the two wires too gether and isolate them,if problem your dryer will start,replace,but its a thermal fuse so the idea is if it gets to hot they open to stop fires,so mcheck all venting and dryer air waysGod is good,tom
Jan 02, 2009 | Dryers
Dryer gets hot and a fuse keeps burning out model number le577oxwno
If you are referring to the FUSE in your house service panel and that IT keeps blowing, then you may have a loose cord wire at the dryer or mating receptacle. Always remove or disable power form these wires BEFORE performing any service. If you can extend the dryer away from the wall and examine the terminal block where the cord ( with ring lugs) is tied to it..check for any sign of carbon ( which would indicate a high impedance junction) meaning that it will get hot and may cause a fire.. Remenber, always remove or disable power from this circuit prior to working on it.. Good luck.. and hope this helps..
Sep 06, 2008 | Whirlpool Dryers
Where to put the cables on j10. powew, hdd, reset etc
the cable coming from your monitor goes in the blue or white port,the network or ethernet cable goes in a large phone plug, the speaker cord goes in the green port and the power cord for the computer goes in the black port
Jul 14, 2008 | Compaq Computers & Internet
To much voltage put into tom tom.smell of burning
when you plug in the normal cigarette liter into the socket does it pop up hot? if so I suggest trying to replace the power cord to the tom tom. your car only puts out 13.8 volts. any more than that the fuses would blow.
Apr 21, 2008 | Tomtom ONE GPS Receiver
Ricoh 1027 copier no powew at all
The problem may be one of the internal fuses. Whip the side panels off (with the machine unplugged of course) and check the fuses on the power supply boards.
Feb 18, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
GPS Logo
1,938 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
