Question about Refrigerators
Please help my fridge comes on and off the lights work, the fan is blowing, but my compressor runs for 5 seconds and shuts off for maybe 3 to 4 minutes.
  • maaneb30 Apr 11, 2008
    i changed the overload and the starter fuse but still doing the same thing and my compressor is getting hot is that normal
  • lovenwolf2 Apr 23, 2009
    Compressor will not run. I have only 8.4mV going to the compressor.
    Genius:
  • 1,073 Answers
You have a bad overload or bad compressor
Posted on Apr 11, 2008
Samsung Refrigerator RS261MDPN starts up when plugged in for about 10 seconds then stops. The center light of the freezer temp indicator blinks. compressor does not run in this mode. Also,is the...
Samsung fridge wont start compressor right away. There is delay, so when you plug fridge in it take 15 - 20 minutes to start.To check if fan is running, you need magnet. Place it on top of door hinge. Open door and if lights are out, you are in wright spot. Take magnet of to test if lights come on. Now put magnet back and if fridge fan is running you can feel it how it blow from different outlets inside of fridge .
Jul 23, 2011 | Refrigerators
Fridge question
Sounds like you mad have a bad relay or overload on the compressor. I would also check your condenser fan motor to make sure its running and blowing air on the compressor to cool it. If its not running the compressor may be overheating and shutting off on its overload. If the condenser fan motor is running I would assume that you would need a new relay and overload it will come in a kit. Usually it will make a clicking sound when the compressor is TRYING to start and then shuts off on its overload if the start components are bad.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Whirpool Refrigarator Compressor Very Hot Will Burn You and Is not Cooling Properly It is letting freezer melt and not barely cold inside
hey
you either have 3 things an over heated compresser, this wouldnt allow the compressor to cool anything beacuse it has an overload which kicks out once the compressor is too hot, and the compressor doesnt work without the overload. solution: get some paper towels, UNPLUG THE FRIDGE, and run some cold water on the towels and use them to cool the compressor, i like to get like 4 or 5 towels wet them and put them on top of the compressor and get another 4 5 towels wet them put the un the bottom front of the compressor. than use another 4 5 towels and cool the front by just rubbing the middle front. keep repeating this until your compressor is not hot anymore like luke warm or better than buy a 3 in 1 its like 20 dollars and install that ( if you need help i will be more than willing to walk you trough it over this or you can call me too)
and the second thing that it can be is overheated compressor due to the condesner fan not working, and thats simple fix just see when you turn on your fridge and turn the dials all the way up to 9 or w.e option you have. see if the fan by the compressor is working if not replace it its also like 20 bucks
or 3 the worst case scenerio free-on leak it has no freeon and the compressor keeps keeeps working to cool the fridge but it cant without freeon so due to the excessive working lol the compressor overheats and shuts off  if thats the case buy a new fridge
if you want to email me with a response  please do so at manison88@aol.com
Jun 06, 2009 | Whirlpool GD2SHGX Refrigerator
New Fridge beeping but no cooling
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Relay on compressor clicks, but does not run
Hi!!! change the current relay in your compressor easy fix..its located inside the case where the wires go connect to the compressor..good luck..
Jan 04, 2009 | Amana ASD2626HE Stainless Steel Side by...
GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Jul 24, 2008 | Refrigerators
Air conditioner problem
You may have an extremely intolerant cold control, a weak gaurdette on the compressor, a compressor motor winding issue, or maybe an oversized unit for the area you are trying to cool.
May 30, 2008 | Heating & Cooling
Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
May 10, 2008 | Refrigerators
Control panel lights blink and beep, freezer fan cycles
The column between the doors being warm usually indicates that the compressor is running properly but the condenser fan at the bottom rear that cools the condenser and compressor is not running. Remove the cover from the back of the machine and verify this fan is running. It could have stuck from sitting for a period of time or something has gotten stuck in the blade during the move.
I am interested in what the fan inside the freezer is doing. You say 3-4 second pattern, is it running a few seconds then off a few seconds?
Please post back with the exact model number from the decal inside the fridge and I will look it up and see what I can come up with.
Nov 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
FRIGE AND FREEZER ARE WARM NOT WORKING
Make sure you hold the door switch closed too check if the evaporator fan is working also check if the evaporator coils are froeen up..
Sep 15, 2007 | Refrigerators
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
