Question about Gateway MX6920 Notebook
Network adapter: Device manager can't find network adapter
The computer has an internal Marvell Yukon 88E8038 PCI ethernet adapter. All of a sudden after working for almost a year, the Device Manager does not recognize its existence. I have downloaded and re-installed the driver. No luck; non expected since the device is not there. I have tried all modes of "Add Hardware". I have tried "Application and Driver" recovery, but nothing of wired ethernet is even on the list as recoverable. I have tried system restore, but it reports nothing has changed. I would do a full system recovery, but I cannot face re-installing my applications.
I am not afraid to edit the registry if I knew where to look and what to look for.
Any ideas?
Laertiades
  • Laertiades Apr 11, 2008
    Yes, the PCMCIA card works fine. This will really sound lame, but the socket is in the most in-the-way location on the notebook. How dumb is all this!
    Thanks for your help.
    Laertiades
I have had these network adaptors go defective. In your laptop, it is probably built in on the mother board. This would be very expensive to fix. I would suggest to get a USB or a PCMCIA (laptop socket) network adabtor. Install the new adabtor with the software that comes with it, and most likely the new one will work.
Jerry G.
Posted on Apr 11, 2008
My computer keep turning on after shutdown
Right click "My Computer"
Select "Properties"
Go to "Hardware Device"
Click "Device Manager"
Select "Network Adapters"
Select "Marvell Yukon .....PCI-Fast Ethernet Controller--> right click ---properties--->power management-->deselect "Allow the computer to turn off this device to save power"--->Go to "Advanced" tab--->put value off for "Wake from shut down" --->value none for "Wake up capabilities"
press OK
Jul 03, 2014 | Computers & Internet
Samsung laptop, just reinstalled win 7, getting 'ethernet cable unplugged' problem, can only connect with wireless. have tried the dry reboot approach and the setting of duplex to fixed (100mb full...
While connected to internet via wireless:
  1. Press windows button + R
  2. Type "devmgmt.msc" press enter
  3. Under the "network adapters" tab there should be a issue.
  4. Right click on the issue driver, and click the option to locate drivers.
  5. Otherwise go to http://www.samsung.com/us/support/downloads
  6. And put in your exact model #
    (Would have found it if you provided it)
  7. Download the LAN driver.
Sep 27, 2013 | Marvell Yukon 88E8056 PCI-E Gigabit...
Network cable unplugged
If it's saying that the network cable is unplugged then your drivers seem to be working. Check the back of your computer to see if the cable isn't plugged all the way in. If it is then go to your router and cable modem to see if they are both turned on and both working properly.
May 24, 2012 | Marvell Yukon 88E8056 PCI-E Gigabit...
Acer Aspire T180 Desktop Unidentified Network but Device is working Properly
Check your IP address settings.
Some-times they need to be set to Obtain Automatically. Unless an address is specifically given to you by your Internet Service Provider.
Take care!
damnor01
Apr 28, 2012 | Acer Aspire T180 PC Desktop
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
Need drivers for ibm 10/100/1000mbps gigabit ethernet low profile pci express adapter Item#53y4005-co
This card is equivalent to the
Marvell Yukon 88E8075 PCI-E Gigabit Ethernet Controller
This should be the correct driver:
http://www-307.ibm.com/pc/support/site.wss/MIGR-74413.html
Follow the instructions at the site.
Apr 11, 2011 | IBM 10/100/1000Mbps Gigabit Ethernet Low...
Cant Find Ethernet and Wireless lan Drivers
Use the Driver Genius Professional Software to get the updated drivers for ur pc
Apr 19, 2010 | Toshiba Satellite A205-S5804 PC Notebook
I got problem in networking
It is a general problem for all TOSHIBA laptops. Its pretty hard to detect toshiba's in network. Trying using another driver software after uninstalling the current one.
Mar 06, 2009 | Toshiba Satellite A60 Notebook
Cannot find network 1394 network adapter nor the standard Network Adapter connection
Try having a System Restore on your computer back to the date before you installed the wireless HP printer device and software.
Sep 13, 2008 | Computers & Internet
Gateway MX6920 Notebook Logo
122 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
