Question about Gateway MX8711 Notebook
Gateway MX8711 no power, battery.....what?
My laptop suddenly wont turn on. When I press the power button the red light flashes like the battery is dead. The computer would not power on or charge when plugged in. So I thought I had a bad power cord. I used my circuit tester to see if I was getting power all the way through the power cord. Sure enough, I was. Power cord is fine. Then I hooked up my circuit tester to the part the connects to the battery to give it its charge, sure enough, I got power there too. So I thought I had a bad battery. I ordered one and got it in the mail, put the battery in and plugged it in. Nothing happened. I didn't even get the blinking red light that the other battery gave me. There is a little meter on the battery itself and the old one shows its lowest level on the meter, and the new battery shows nothing.
I thought that the computer should still power on without the battery and still plugged into the wall outlet. Mine doesn't. What could be the problem?
The only thing that I think I could check is the CMOS battery, I could replace that, but I cant power the computer on to get the current settings to input if the computer does power on afterwards.
SUGGESTIONS PLEASE.....THANKS!!!
  • 9 more comments
  • mountain510 Apr 11, 2008
    Is it possible for power to get to the battery without going through the motherboard? My circuit tester shows power going to the battery at the battery connection.
  • weirdscience Jul 27, 2008
    I am having the same issue with my MX8711 notebook. I was using it when it stopped and powered completely off. I have contacted Gateway and they want me to sent it in. The online support indicated it was the AC adapter. I have checked it and have 19.2VDC on the load side of the adapter. I went to Best Buy and they told me the same thing with the AC adapter. There is clearly an internal issue that they don't know or won't admit. I have tried to take it apart and have stopped due to the difficulty in getting to the backside of the mother board. I you hear of any other solutions let me know. Thanks
  • computerpain Jul 31, 2008
    I am having the same problem with my MX8711. When I push the power button the battery LED flashes red. I can not use the laptop without the battery, either.
  • Tony Lane Aug 10, 2008
    I have the exact same problem. It is related to the power port I believe. I think the connection is loose and it needs to be repaired. I hate Gateway. I will never buy them again. I had issues with the power adapter also and I had to buy a replacement after only 6 months!
  • 1steflik Dec 08, 2008
    tried to get to the mother board to check the connections. Cannot get the top piece off. (The one with the keyboard on it) The two hole where the top latches in are holding it from comomg off. Due you have a clue on how to unfasten these two latch holes?
  • D Porter Dec 17, 2008
    i have the same exact problem as the others, yet when I use my roommate's power adapter the laptop works fine. It charges up properly and everything. Two totally different brands of adapters.....very wierd
  • momacinm Feb 28, 2009
    I'm having the same exact problem. Did you get yours fixed? Everyone keeps telling me it's the AC power cord too.
  • Anonymous Mar 03, 2009
    i have the same problem. i bought a new ac adapter and it has worked fine for the last couple weeks. the adapter has a green light indicating that it is working. however, my laptop won't even show that it is charging, nor will the red light flash when i try to turn on the computer.
  • SteveNYC78 Apr 06, 2009
    I have an MX8711 that shows NO LEDs at all!  It was running and then made a loud POP and then shut down.  It never turned on again - either plugged in or with the battery.  Nothing.
    I've disassembled the entire PC.  The power adaptor is fine according to my voltage meter.  The DC jack is solid and doesn't seem to be broken at all.  There isn't any other obvious sign of damage.
    Does anyone have a solution for this?  Should I replace the power button module (the little circuit board with the USB/Ethernet/Modem jacks)?  I can do my own soldering.
    I'd really appreciate any help you could provide!  Thanks!
  • bobb4965 Apr 14, 2009
    No power what so ever and dc plug in reads good on multimeter. Is there a fuse on board somewhere?. help please
  • Anonymous Apr 24, 2009
    no power, had the ac adapter tested and its fine. battery drained out. tryed to turn on computer, flashed up for a few seconds and then died.
1steflik:
To disassemble:
1) remove the four screws on the rear of the two top hinges
2) fold the screen all the way back and unsnap the small bezel above the keyboard. Remove
3) remove three top screws holding keyboard, unplug, and remove
4) remove the center motherboard screw which was under the keyboard
5) Now you're ready for the main action: Remove battery, HDD, memory cover, memory
6) unplug WiFi antenna wires on bottom (under memory cover) and thread back through hole
7) unplug display and display backlight
8) remove all bottom case screws and top case screws
9) gently work around the top bezel, unsnapping it as you go around, and remove.
Posted on Feb 04, 2009
  • 46 Answers
Does the connection on the notebook wobble badly if you plug in the adapter and try to wiggle it? If so, the solder joints that connect the power socket to the motherboard may have broken. This means no juice to the main board OR battery, and explains why you can't use the notebook without the battery. If you want to try to fix it yourself, I couldn't find a link to a service manual, so you'd have to wing it. But you can't make it not work any worse. If you try this, you will have to completely disassemble the unit to lift out the motherboard and flip it over. Take photos/draw sketches, and keep different hardware separated.. When you get to the back of the board, if the power socket solder joints are broken, but look resolderable, FIRST turn the board right-side up and epoxy the socket the the board. When the epoxy has set, THEN resolder the connections using a low-wattage iron (not a gun). Reassemble it, cross your fingers, and plug in the AC adapter. If the charging indicator lights up, the notebook should now work.
If you take the notebook to a service center, it will probably cost more than the price of a new notebook.
If you want ME to give it a try, you would pay shipping both ways to Northern California, and $20 just for me to see if I can get to the socket. If I can't, that's all you pay. If I can get to the socket, but it's not fixable, you would pay another $20 for me to put it back together. If I can fix it, your total would come to $100 (plus the two-way shipping). You would get a 90-day guarantee.
Posted on Apr 11, 2008
This seems to be a very common problem with the gateway MX series laptops. The shop that I work at probably sees at least two or three of these machines every month. As far as we can tell it is a failed charge circuit that requires a full motherboard replacement. This however is a suboptimal fix because any replacement motherboard will presumably have the same problem down the road.
Generally we tell people that gateway sucks and that they should replace it with something else.
Posted on May 28, 2009
Hi everyone, I just had the exact same problem as SteveNYC78. I was working on the computer, went to the start menu to put it in sleep mode. The minute I clicked sleep, there was a pop sound and the computer turned off. There are no LEDs lit for anything not even to tell me the power plug is plugged in. It is dead as a door nail. Will not turn on and nothing lights up on it at all. Also, I head a click click click click noise every minute or so coming from around/underneath where the memory is located inside the machine. What the heck? What could have happened?? Please help.
IF there is no way to get this thing turned back on, is there an easy way for me to get files off my hard drive??
Thanks!
Posted on Jun 16, 2010
4 Suggested Answers
cdhardy
  • 111 Answers
SOURCE: Gateway MX8711 USB 2.0 problem
it`s normal when you plug a usb 2.0 device into a usb 1.0 port i get that all the time it`s ok
Posted on Mar 30, 2008
  • 39 Answers
SOURCE: gateway mx8711 keyboard
yes
Posted on Jan 12, 2010
  • 7 Answers
SOURCE: Gateway MX8711 ran hot. Now will not power up
It sounds like the laptop has had some sort of thermal problem. Do you use it in a dusty/dirty environment? Did the laptop blower fan seem louder than it normaly was in the past? Any number of things (including age) could cause a laptop's fan to stop/work ineffectually and cause it to overheat.
Posted on Sep 30, 2010
Computer will power up but not boot. Screen remains black. Battery charges.
If the screen's backlight doesn't come on at all, that's a new screen. You can find more from Gateway's support website. If the screen lights up but stays completely black, that's a motherboard issue, same fix. If the Gateway logo comes up but never goes into windows, that's most likely a hard drive issue, same fix. If you see an error message from Windows, that's a Windows issue. You could use the recovery DVDs that came with the system to fix that. Just put them in and turn the computer on. Press F8 repeatedly until you see an option to boot to DVD. Then follow the instructions.
Please rank if this was helpful.
Mar 05, 2011 | Gateway MX8711 Notebook
My MX8711 won't power up. The power light doesn't come on, it only flashes red 4 times and then nothing. What does the flashing red light indicate?
It could be realted to your faulty Battery.
Please remove the battery and connect the Power cable. Now switch on the laptop without battery (Make sure Power connector should be connected and switch ON).
Check whether its getting ON now or not.
Sep 25, 2010 | Gateway MX8711 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
I have a Gateway MX8711 Laptop and all of a sudden it powered off and even when I plugged in the power cord thinking that it may be the battery, it still will not power back on. What could be the problem?...
It should still run while plugged in dead battery or not. Depending on the age it may just have worn out. Power supply may be dead, that would be my guess.Most shops will charge a $70 fee to test it.
Certain years of brand new Gateways has a horrendous history of dying leading to a lot of "refurbished" machines being unleashed on the public.
Feb 28, 2010 | Gateway MX8711 Notebook
Gateway laptop model W350i will not boot. When power button is pressed, red light flashes four times. Replaced AC power adapter, tried removing battery and power with AC only, still does the same thing. ...
It's a hardware failure like a cpu fan not working or faulty ram.Check the gateway site for an explanation of the lights. It's flashing a trouble code.
Jul 12, 2009 | Computers & Internet
No Power to Gateway Laptop
Michelle,
Check the fan vents... if they are clear of dust and lint. If there is some it may need a cleaning inside also.
Since the battery is light is "red" remove the battery. It could have been over heated or shorted outinside.
If it dont power up at all with only the AC adaptor (removing the battery) then try the reseting the "Reset" button under the unit.
Jan 03, 2009 | Gateway Computers & Internet
Gateway MX6438 will not power on
if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Dec 29, 2008 | Gateway MT6730 Notebook PC
Laptop Gateway mx8711
Gateway laptop is really ****.
I bought Gateway MX8711 in March 2007, after 6 months i use it...the hard disk failed.
Gateway replaced a new Hitachi hard disk for me but not more than 8 months and it failed again.
Gateway told me that i have no more warranty because the repair warranty is only 90 days.
I bought this laptop and use it not more than 2 years, the hard disk was failed twice.
Usually Hard disk manufacturer provided 3 years warranty for the hard disk. The manufacturer year of the hard disk is May 2007....they should able to help because the har disk not more than a year being used...but they don't. This is really bad customer service and not fair to the buyer.
I will not buy any Gateway products anymore....i swear.
Jun 24, 2008 | Gateway MX8711 Notebook
Battery Charging Gateway MX8711
How to replace the CMOS battery. In some cases this can charge the battery and resolve your issue. This often resolves CMOS battery related issues when a computer has been left off for ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Gateway MX8711 Notebook
Gateway MX8711 Notebook Logo
3,759 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
