Question about Texas Instruments TI-30XA Calculator
Exponents How doyou input simple powers with imaginaries for ex: (4+5i)^6?
    New Friend:
  • 136 Answers
X/;==
Posted on Apr 11, 2008
Every time I use exponents, I get the right numbers, but the wrong decimal point.
Since exponents are hard to type, we usually use the carrot key, "^".
I get the correct answer on my calculator. Could it be set to scientific notation and there is a "-1" off to the right?
Let me know.
Good luck.
Paul
Mar 07, 2016 | Office Equipment & Supplies
How to enter exponents ex. 10 to the 4th power???
Press 1 E 4
The E means "times 10 to the" so 1E4 is 1*10 to the 4th 10 to the 4th.
Oct 16, 2013 | HP 33s Calculator
How to figure exponents
use the up caret for exponents
ex: 10 to the 2 is 10^2
Feb 27, 2011 | Texas Instruments TI-30 XIIS Calculator
How would you do negative exponents for scientific notation? example: (6.0 x 10^6)(2.0 x 10^4), I am required to use the EE button for my exponents since it's a scientific notation equation but I do not...
Use the (-) key for negative numbers (not just exponents) instead of the - key. The - is to subtract one value from another, (-) is to input a negative value.
Sep 09, 2010 | Texas Instruments TI-30XA Calculator
Can you have negative exponents appear as a regular decimol?
I am not sure what you mean. I will try to guess.
If you use the universal power key marked [^] you can use any type of exponent, Just enclose the expression for the exponent in parentheses to avoid ambiguities.
EX: exponential of -3X+5
[2nd][LN] [( ] [(-)] 3 [X,T,Theta] [+] 5 [)]
If by exponents you mean powers the result will be displayed usually as decimals.
I suggest you enter the calculations you have to perform and press [ENTER]. The calculator will inform you in case of ERROR. In case of error with message QUIT or GOTO, select the GOTO option and you will be taken to the offending entry.
Jun 14, 2010 | Texas Instruments TI-84 Plus Calculator
Have a TI30Xa, i am trying to input 100 micro squared. how do I do this?
Usually you do not use the prefix micro by itself, it must be followed by the name of a unit: 1 micrometer=10^-6 meter. This being said, you want to enter 100*10^-6 and raise it to power 2.
For this you can use the exponent rules.
  1. 100*10^-6=(10^2)*(10^-6)=10^(2-6)=10^-4; product of powers =>algebraic sum pf exponents
  2. (10^-4)^2=10^(-4*2) =10^(-8) ; power of power =>product of exponents.
With your calculator: You have a key near which is written [10 to x]; you access the function with [2nd][10 to x]
In what follows, I will enter (10^-6)* 100 and square it. I will use the change sign (-) or [+/-] key
(-6) [2nd][10 to x] [*] 100 [=] [x^2] [=]
The first = calculates 100*10^(-6), the second [=] calculates the square of the number obtained after the first [=].
There are other ways that use parentheses to avoid ambiguities, but I think this is the safest one for you. Be warned that the result will most likely be displayed in scientific format, 1.00 -08 where the -08 will be raised with respect to the main level line. If not, the result will be 0.00000001
Feb 17, 2010 | Texas Instruments TI-30XA Calculator
Decimals in the exponents for TI-30Xa
You have a key labeled [Y to the x], use it for all the powers or roots that do not have a dedicated key or key sequence. Let the key be [^]
Ex: 13.675 to the power 1.33 is entered as 13.675 [^] (1.33) [=].
The result is 32.41778634
Ex: (-64)[^](2/3) [=] gives 16 as result. The (-) is the change sign key
Ex: (2.87655)^(-6.778) is entered as 2.87655 [^] ( (-) 6.778 ) [=] 0.0007758
The (-) is the change sign (or the negative of), not the regular minus. When you have a negative exponent or a complicated exponent, it is safer to enclose the whole exponent inside parentheses.
Hope it helps.
Thank you for using FixYa
Nov 21, 2009 | Texas Instruments TI-30XA Calculator
Using imaginary numbers in a matrix
Press MODE and select one of the two complex modes.
Mar 30, 2009 | Texas Instruments TI-84 Plus Calculator
Entering a problem
Hi Loringh,
see, high exponents are +ve powers, while low exponents are -ve powers.
e.g. for 1200000=1.2X10^6=1.2E+6 (high exponents)
for 0.0000000012=1.2X10^-9=1.2E-9 (low exponents)
I think so easy ?
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
9899780221
Dec 12, 2008 | SoftMath Algebrator - Algebra Homework...
Texas Instruments TI-30XA Calculator Logo
472 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
