Question about SanDisk Sansa e260 MP3 Player
Mp3 Player not reading SD 1GB Card
So basically - I've looked all over the internet for a solution to my problem but nothing seems to work.
I have a Sansa e260 model (4.0 GB) player. I also have the 1 GB micro SD Lexar chip for extra storage. Basically, I end up putting some songs onto the SD chip and the computer reads them perfectly and I see the card as a removable disk. However, when I insert the chip into my Sansa e260, the mp3 player recognizes the chip and does "Refresh Database", but it does not recognize any of the songs I have placed on my SD chip.
I have attempted switching the USB settings, but that does not seem to help because I still cannot see the songs. And secondly, I have noticed that in "my music" folder on the SD chip there have been 3 new folders created which I don't have access to because those locations are unavilable.
Hoping that someone can shed some light on my situation. The card itself is fine because my cell phone can see the files on it, and the mp3 player itself recognizes songs from my friend's SD chips.
Thanks in advance - Igor.
    New Friend:
  • 136 Answers
The Sansa is unfortunatley one huge mess up the programming has failed its working on a database with only 4 levels but for grphics and songs you need at least 7 lhopefully you can return it and get another if not you can try putting another type of chip hopefully that will work
Posted on Apr 11, 2008
RCA pearl 4GB expandable memory?
The card you are trying to use is likely a high capacity sd card (SDHC). This player does not support high capacity cards, it only supports microSD cards that are non-high capacity (I think most of them are usually 2GB or less, but you can find them up to 4GB).
Nov 30, 2009 | RCA Pearl TH1102 MP3 Player
MP-F70 doesn't read 1GB SD Card
I think the problem were some of the files.
They were downloaded to the MP3 ewith out name.
I downloaded them from another computer and it worked fine....
maybe just a glitch
May 07, 2009 | MPMan MP-F70 MP3 Player
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
Aigo F529
I'm confused. Are you saying that you can't play files on the SD card from the computer itself? Or, the songs won't play on the mp3 player once the SD card is loaded into the mp3 player?
First, make sure the songs are in the right format - each mp3 player will only play files of a certain type. Your best bet is to only use Mp3 format files -everything else is going to give you one problem or another.
Second, there is a size limit to what type of SD card the mp3 player can read. 2GB SD cards are the absolute maximum that this player will handle, and probably only 1GB even.
Hope this helps a little.
Jul 06, 2008 | AIGO F008 MP3 Player
Accessing MicroSD Card - Sansa c240
wlubbert,
The memory won't read 9GB. It should read 1GB of the built-in memory, and then 8GB or slightly less from the SD card. They are actually separate "drives". From this standpoint, it seems like there are 2 possibilities:
1) The player isn't compatible with that new, top of the line SD card. (Most likely the case.)
2) The card is defective and needs to be exchanged under warranty or your money refunded.
Please let me know if this helps. Good luck!
Feb 28, 2008 | SanDisk Sansa c240 MP3 Player
Memorex MMP3642A - SigmaTel format
A few suggestions:
1] I’ve tried using a 1GB sd card in the MMP3642A with no success. Interestingly, I can transfer files to the 1GB card when it is in the MMP3642A, but when I turn on the player to listen to the files, I get the sigmatel formatter error message. I tried running the sigmatel formatter, but it doesn’t understand the 1GB size. Apparently whoever programmed this braindead formatter program only programmed it for up to 512MB sd cards. Interestingly, I tried flashing this player with the MMP8500 firmware, and then the player does play files off of the 1GB sd card, but the LCD is mostly cutoff and only 25% of the LCD shows up. So it seems the only obstacle to using a 1GB sd card is this stupid formatter program. I tried formatting the sdcard to fat16 instead of Fat32, but that did not help
2] If you want to use a card with more than 64MB, you need to use the CD that was with the player. DO NOT USE AUTORUN! Explore the disc, go into the "products" folder, run the stusbmscformat.exe application. It will show a the drive letter for the player, click the arrow and select the next drive letter down, then press start. This worked for me, I hope it will be useful. Why memorex doesn’t address this issue is beyond me.
3] How do I correct the error: Reformat external media with sigmatel formatter? If you have installed the software disc that you received with your MP3 player, you will need to follow these instructions; -- From your computer, click 'START' -- then 'PROGRAMS' -- then 'MEMOREX' -- then 'FORMAT' -- choose the 2nd drive If this doesn't correct your error, you will need to return the memory card to the retailer for an exchange. connect your memorex mp3 player , then turn it on and click start .....i did the same and its working now.
Jan 08, 2008 | iLO MP3 Player
I bougth a 4GB SDHC card for my 1 GB ilo w/expansion slot, will it work
my new ilo 1gb mp3 player's manual reads: you can use up to a 1 gb sd or mmc card. hope this helps. :)
Nov 30, 2007 | iLO MP3 Player
Largest SD Card Size???
The 4gb cards are called SDHC(secure digital high capacity), check the packaging for the sdhc logo, if it just says sd your max size is 2gb.
Sep 23, 2007 | Harley Davidson Road Tech HA90 MP3 Player
I have the player, memory question...
I've had a 1gb sd car for two years or so and never had any trouble. I'd like to hear the answer on the question whether 2gb cards work, too, though.
Aug 30, 2007 | Motorola Mobility M25 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
107 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
