Order parts The bulb/lamp broke on my rear projection 46 in. I need to order the part to the tv, a remote for the tv and the manuel
  • 8,617 Answers
Heres a link to get the lamp.
heres a link to get a remote.
and you should be able to get the user manual by entering the model number into the search box for free at this link
Let me know if you need further assistance
Posted on Apr 11, 2008
How to replace procector lamp in model 46h84 toshiba
Projection TV sets have three tubes - red - blue - green and they don't fail often...they are located inside the tv DLP TV sets use a single bulb and a clot wheel to make the three colors display...DLP bulbs do fail about every two years and will need o be replaced. Replacements can be found at and its located behind a small door on the rear of the tv.
May 19, 2013 | Toshiba 46H84 46" Rear Projection...
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
4. To change the Data Value, press 3 or 6 on the Remote
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
I replaced the bulb today and the red lamp still flashes. alsol the tv automatically starts when i plug it in.
Check Lamp Fan and the Ballast board that Lamp connects is what powers Lamp. Encompass Parts 1-800-638-3328
Feb 20, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Call your manufacturer and see if they have a parts request email or number. You can then order/purchase part and have it replaced.
Aug 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Looking for lights....
You can find replacement parts for this model from the following Sony OEM parts distributor. Here's the links to order the original Sony blue CRT, green CRT, and red CRT (the 3 "light bulbs") for this model from that major parts distributor if needed:
Sony KPR-53CX35 Replacement Part Blue CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Green CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Red CRT Bulb / Lamp
Apr 01, 2009 | Televison & Video
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
Feb 17, 2009 | Philips 43PP9202 43" Rear Projection...
Heard a POP then no picture!
You need a new bulb, my tv did the same thing.
Dec 24, 2008 | Hitachi 46BX01B 46" Rear Projection...
Lamp error
keep an owner manuel, can download one online, but you need to replace the bulb, then reset the counter. to reset the counter press (-) volume on the tv then while holing that down press the pip button on the remote that will reset the counter
Jul 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
color wheel brakes then causes this same affects check your wheel
Nov 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
