Are you trying to connect to your internet connection for wireless? If it is, the WEP key is the password that you set up for your wireless device so that devices that can see the your wireless network will be able to connect by entering the right WEP key. If you didnt change the WEP key of your modem or router, then the default WEP key will be found at the back of your device, but if you had changed it before then, that's the WEP key that you need to enter.
A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders.
A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F. Some examples of WEP keys are:
1A648C9FE2
99D767BAC38EA23B0C0176D15
WEP keys are chosen by a network administrator. WEP keys are set on Wi-Fi routers, adapters and other wireless network devices. Matching WEP keys must be set on each device for them to communicate with each other.
The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
A WEP key is a security code used on some Wi-Fi networks.A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F.
40- / 64-bit WEP: 10 digit key
104- / 128-bit WEP: 26 digit key
256-bit WEP: 58 digit key
WEP keys are chosen by a network administrator, it would have been provided by the Internet Service providers, Hence it can't be as what you stated.
WEP stands for Wireless Encryption Protocol and it is the wireless key for your router.
You will need to find the WEP key in your router's administration page and then enter it on your xbox under the system settings then network settings.
Unfortunately, no one could not provide you any WEP key. WEP is a key that you set to your router so that no one could connect to your wireless network. As an owner of the network, you should know what your network key was.
If you forgot your WEP key, you need to reset the router to factory default, configure it and set a new WEP key.
To locate your wep key.log into the router under wireless security there you should see it.If not you can use a paper clip to reset it.The hole is at the back next to the ports.
Good luck
your wep key should be on the equiptment like the router on the bottom if not, make a new wep key if u have a pc go in to the settings of the router enable wireless and add ur own wep key or is the wep already on a pc and ur connecting to it from ur console then input manualy i dont know if wireless is anygood for a ps but try wired see if that is more helpfull
