Question about Microsoft Xbox 360 Console
No color where in settings would i find pal
  • 472 Answers
It should be in the video settings page. Press setup on the remote.
There will be other options that could be currently set as one of these - AUTO, NTSC, PAL
Posted on Apr 11, 2008
How do I make it play in color?
what color system is tv and what color system is dvd set to.
PAL to PAL
NTSC to NTSC
NTSC to PAL = no color
PAL to NTSC = no color
Feb 17, 2016 | Televison & Video
My tv has gone black and white I dont know how to get the colour back
check color system matches . If tv uses PAL then DVD player needs to be set to PAL. If TV station uses PAL then set devices to PAL. If TV station uses NTSC set devices to NTSC for color system.
Aug 06, 2015 | Televison & Video
Why does it only play dvds in black and white
check color system settings pal to pal
TV PAL then DVD player has to be PAL
TV NTSC then DVD player needs to be NTSC
If mismatch in settings you may experience black and white
Dec 31, 2014 | JVC TH-A30 System
Change ntsc to pal
The manual seems to indicate that the TV will automatically detect what signal type is present, so PAL should be recognized. There is, however the possibility that the "Color System" setting under the system menu may not be set to "AUTO", but NTSC. This would cause a conflict when detecting PAL input and affect picture. Check the "Color System" and either select PAL or AUTO and see if that helps.
Sep 18, 2014 | Televison & Video
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
Works ok but no color
please check your PAL or NTSC settings on your TV.
if system is set up to work on PAL and your tv is set up to work with NTSC, for example, you will really get no color,
Jul 30, 2009 | Nintendo Wii Console
My yamaha dv-s5650 is only playing in black & white!
That's a problem with the video IC it might shorted. You need to send your TV now to the nearest electronic repair center and have it fix there.
Jun 29, 2009 | Televison & Video
Picture Rolls
anteetina,
most probably your problem is within color system settings. It's either PAL/NTSC or PAL SECAM signals being produced by your player.
1) try to check your TV screen with regards to color system it use, check the color setting if it does indicate "Auto" "PAL" or "NTSC" try to choose "auto" and see if any changes will occur.
note: you can also check the service manual of your DVD player of what color system it produce and if it's match with your TV screen
cheers.
mark
Jan 15, 2009 | Digix HT1056A DVD
When I hook my playstation 2 to my trutech tv, it plays in black and white. How do I get it to play in color?
You need NTSC TO PAL converter or a RF converter for this problem.
your console must be of NTSC type and your TV PAL type or vice versa.
check your tv settings to change from pal to ntsc to get color. Mostly modern TV sets would have the settings to change on their remote controller from ntsc to pal, secam etc.
Dec 18, 2008 | Bethesda Softworks Black & White
Original DVD plays black and white
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Aug 18, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
