Question about Apple Mini IPod
I pod wont turn on
I put my i pod accidentally in the washer, and it wont turn on as long *** i connect the usb cable. but even then it wont go to the screen. what can i do?
  • Anonymous Jan 05, 2009
    my ipod got left in my sweater and got washed and now it wont turn on and my sister told me to put it in the freezer and that didnt work either but you can try it. it wont hurt.
  • bethmichelle
    bethmichelle Jan 09, 2012
    try hairdrying it mine went the same and i toch it to the shop and they simply said to hairdry it and it worked for me so it might work for u xx <3
I have put my ipod to be recharged but its taking too long and dosent seems to be charging
Posted on Nov 05, 2008
    Champion:
  • 230 Answers
I would let it dry out and pray the board didn't get damage. Chances are you will have to buy a new Ipod or replace the everything (which will cost more then ipod itself)
Posted on Jun 27, 2008
2 Suggested Answers
SOURCE:
SOURCE: My ipod wont switch on
ok same thing happen 2 me.
first you switch the hold switch on and off then hold down the center button & the menu button for 6 seconds or until the apple logo appears
Posted on Dec 05, 2008
The agitator wont turn even by i cant turn it
"the agitator wont turn even by i cant turn it"
Do you wake up in the morning with the goal of butchering the English language or does it happen accidentally?
Mar 20, 2011 | Kenmore 22422 Top Load Washer
I took my 92 jeep wrangler's distributor cap off, put it ack on, and put all the wires back on. Now it wont start, it wont even turn over.
If the engine won't even turn over, it has nothing to do with the cap or wires. Perhaps you accidentally damaged or disconnected the battery cable to the ground, or one of the wires going to the starter? These are located in the same general area.
Dec 01, 2010 | 1992 Jeep Wrangler
Wont connect to i pod
Ipods don't connect to routers. Ipods plug into USB ports on your computer.
Jul 24, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Pocket Pod wont turn on
MOST pedal devices ENABLE the battery when the INPUT audio cable is inserted (there is a switch on the jack it plugs into). This automatically connects the battery when you go to use it... ALSO if you leave the cable plugged in will DRAIN the battery.
May 02, 2010 | Line 6 Pod 20 Fx Box
My i pod is locked i think
Plug the iPod USB cable into the bottom of the iPod Nano.
  • Step 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer.
  • Step 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
  • Step 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
  • Step 5 Click on the "Sync" button to establish a connection between your iPod and the computer.
  • Step 6 Click on the eject symbol next to your iPod's name after the syncing process has finished.
  • Step 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again
  • Sep 23, 2009 | Apple iPod nano
    Do you have to have a router to connect your ipod to internet
    No you do not require a router to connect your I pod to the internet.
    If you wish to load the songs on the I Pod, you can first look for songs on the internet and save them to your computer.
    Then you can connect the I POD to the compuet via the USB cable which you would have received with the I pod.
    Please connect the usb cable one end on the I pod and the other to the
    the computer. The moment you connect the I POD to the computer, the system will detect the IPOD player. You can then save the copy of songs you have downladed on your I POD player.
    You can select the sond saved on your compuet by doing a CTRL+C key and then go to MY COMPUTER> and under the drives section it will show your I POD PLAYER. CLICK ON THE PHILIPS PLAYER TO GO INSIDE SO THAT YOU CAN DO A CTRL+V and copy the songs on the I POD player.
    That should do the trick and you shoudl be able to listen to your favourite songs on the move.
    Please rate me if you are happy with the support provided.
    Sep 14, 2009 | Apple iPod touch
    My i pod nano won't turn on unless it's pluged
    The ribbon cable from battery to main circuit board is faulty. You could solder new connection or dump
    Sep 12, 2009 | Audio Players & Recorders
    My I-Pod sometimes charges!!!
    have you tried a different usb cable?
    Aug 14, 2009 | Apple iPod MP3 Player
    I connected data cable from usb to my i pod,there is no reaction
    Ur IPod must have been hanged ...check whether the dispay is still on....if yes...then press and hold the menu and select utton simultaneously for 10seconds,or else select and pause button make sure the hold button at the bottom is towards the headphone.
    Aug 05, 2009 | Transcend T.sonic 850 Digital Media Player
    I pod wont connect to itunes
    Try another computer just for the kicks of it and see if does the same. Your computer has this little program deep down call iTunes helper that's suppose to link the USB iPod to iTunes. If it's not working right nothing will happen when connected. If the iPod works on another machine, iTunes helper is the problem or also even bad USB port could be the problem. Send me an update and I'll keep helping you troubleshoot. - Scotty
    Apr 29, 2008 | Apple iPod nano 3rd Generation
    Apple Mini IPod Logo
    Top Apple Audio Players & Recorders Experts
    Parshiv Luthra
    Marvin
    Marvin
    Will Mishler
    Will Mishler
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
