I just bought a Canon MX700 printer/fax/scanner. The fax was working fine until about the time I ungraded my macOS to 10.5 and also upgraded my canon drivers. Could be unrelated. Now two things happen. When dialing, the fax dial tone is a busy signal both when plugged directly into the phone jack (replacing phone line) and also when it is run through the splitter. When it is run through the splitter, the phone line does not work. Suggestions?
Comments:
Apr 11, 2008
- No connection is fine.
Apr 11, 2008
- yeah, I upgraded drivers and still same issue. Could it possibly be the phone service? When I plug in the fax, there is just silence on the phone and I can't dial out now with the fax plugged in.
can I fax through a lan connection and bipass the phone line?
Apr 11, 2008
Apr 11, 2008
- Hi there,
I tested the phone wire by plugging in another phone with the wire and the splitter and both work fine and also simultaneously. So connection and wires are fine. when I plug the same cord back into the fax, then both connections no longer work. thanks for your help.
Apr 11, 2008
- I called Canon and they helped me figure it out. Thanks for your help.
Buisy signal indicates that there is problem with your connection.Please try unpluging all the cable connections and wait for 30min and then plug them all back and make sure that all the cables are connected firmly.
Goodluck,
Please dont forget to rate the solution.
Comments:
Apr 11, 2008
- You can also try uninstalling the drivers first and then install them back again..
Apr 11, 2008
- ok, then try uninstalling the drivers first and then install them back again..
Apr 11, 2008
- Well i believe that is the phone service issue...
Apr 11, 2008
Apr 11, 2008
- I am glad to hear that your problem is solved.
Thank you for using fixya..
Rating Locked! (?) nancesf has rated this solution as Very Helpful
My Printer is saying,
some ink tanks are not installed in place.
I have removed and replaced them...
(More)
I have removed and replaced them a few times and the red light stops flashing then i shut the cover and it still comes up with the same message UO72 !!
The printing and copying functions of my Pixma MX700 work fine but the scanning function doesn't...
(More)
The printing and copying functions of my Pixma MX700 work fine but the scanning function doesn't work. We recently got a new hard drive. Could that have anything to do with this? Does the printer need to be uninstalled/reinstalled?
paper not feeding, used to feed more than one page, now not feeding at all. Want to open up and...
(More)
paper not feeding, used to feed more than one page, now not feeding at all. Want to open up and check roller. Have used all troubleshooting help, manuals, and cleaning kit..
My Canon Pixma Printer MX700 is near new and the screen is showing Error Code 6A80...and the alarm...
(More)
My Canon Pixma Printer MX700 is near new and the screen is showing Error Code 6A80...and the alarm light is flashing.. Does anyone know what the problem is?
