Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
Problem with the Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
Alpine pdx-1.1000
By Briankt69 on Apr 11, 2008
I have a pdx 1.1000 and a pdx 4.150 the 4.150 is running 2 6x8 components and 1 6.5 component set. the 1.1000 is running 4 type s 10" subs. the power wire from the battery is 4 awg with an 80 amp fuse run to a fuse block the amps have 10awg wire run to them. when it turns on it plays fine but if i turn it up and a hard bass note hits the 1.1000 amp cuts off. if I turn everything off and back on the amp comes back on. why is this and what should i do? should I change the 4 awg wire to 2 or 0 awg and 4 awg to the amps like it says in the manual? and if so what size inline fuse do I need and the battery? the battery is stock would an optima yellow top help stop this issue? thanx.... brian
  1. I rewired my amps using Fosgate 0/1 awg power wire with a 300 amp inline fuse at the battery. This travels to a 10 farad digital Voodoo cap (which is grounded with 0/1 awg). Then to a Fosgate fuse block with a 60 amp fuse for the pdx 4.150 and a 100 amp fuse for the 1.1000, followed by 4 awg wire for power and grounds to the amps. Everything seems to be fine now. I plan on very soon going ahead and changing the stock battery with a Kintek HC2400 if it fits. Their website recommends a HC1600 based on my RMS wattage plus another battery by the amps. But I will just change the stock battery out and that is it.
    I was thinking about an Optima yellow top because I have seen them used for many years in car audio installs in magazines but upon farther research alot of people are saying that the Optima's are not the best chose because they are a deep cycle battery and that the Kintek's are the best way to go. What do you think?
Best Solution (1 of 2)
posted 2 years ago
  • Rank: Guru Car Audio & Video
  • Rating: 85%, 1073 Votes
Hello Briankt69,
Ot two issues, First the AMP is going into a protection mode this means that it is drawing too much current. As netrecov said you need a capacitor, this will oppose the rapid current draw, by allowing the voltage to remain constant. However I would also sugget that you rewire the setup to manufatures specification and make sure that all grounds and supply leads are installed properly. Taking into mind the the 4awg wire has less cross sectional surface than the 2 or 0 AWG wire causing it to have more resistance this is power loss in this case (follow the specifications).
I hope this helps
Thank you,
Shuttle83
Was this helpful?
Yes
No
Add a comment
  1. Hello If this setup is drawing a lot of current, you may want to consider adding an extra alternator and battery to make up for the extra current requirements. My suggestion is not to use deep cycle batteries because they are made to provide a steady amount of current over a long period of time and are meant to be deeply discharged, as opposed to normal car batteries which are maed to provide for surge currents (like you are exposing the battery to). Again my suggestion is to install an additional alternator, battery and voltage reg.
    I hope this helps
    Thank you
    Shuttle83
    Reply
Solution 2
posted 2 years ago
  • Rank: Guru
  • Rating: 88%, 21 Votes
what is happening is the amp can draw the current. u need a capacitor
Was this helpful?
Yes
No
Add a comment
Please type the numbers below to complete your post:
Can't read it? Try a different one.
Type the numbers here:
Solve this problem
Bold
Italic
Underline
Insert List
Insert List
Video
Pictures
Insert Link
Links
Share your knowledge with the Fixya community today!
Popular Solutions for Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
can you hook your amp straight to your alternator
can you hook your amp straight to your alternator with no problems
how do i fixs cur code
what is cur code
what is cur code
alpine radio works fine, but only searches fm
alpine radio works fine, but only searches fm stations from 69 to channel 90. Most stations here start at 90 and go as ...
I obtain recently a car amplifier model: mrv-f400
I obtain recently a car amplifier model: mrv-f400 of alpine, i want information about the correct way to instal thanks
Unsolved Problems rss
Jl audio 300/2 amp not working, yellow " Low Ohm"
Jl audio 300/2 amp not working, yellow " Low Ohm" light on
i hooked my amp up
i hooked my amp up but power light does not come on , it is a jensen A250 , fuse is O.K.
when i hook up my
when i hook up my crunch adio amp the protection light comes on. what does this mean?
I have a Chevrolet 2002 Trailblazer with the Bose
I have a Chevrolet 2002 Trailblazer with the Bose Radio with 6 CD changer. For the last 9 months the radio works only ...
My MTX JACKHAMMER 1200 amp keeps blinking yellow
My MTX JACKHAMMER 1200 amp keeps blinking yellow light and amp won't power on.
Solve this problem:
Bold
Italic
Underline
Video
Pictures
Insert Link
Links
What is this?
Get an Expert to Solve your Problem:
Top Car Amplifier Experts
Rank: Guru
Rating: 91%, 6509 solutions
Rank: Guru
Rating: 90%, 2574 solutions
Rank: Guru
Rating: 94%, 648 solutions
Get an Expert to Solve your Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Problem
Get Immediate Assistance!
Let our Experts solve your problem!
More than 2 million solutions and counting...
