Question about Whirlpool GSX9885J Top Load Washer
Not draining the tub
I have a GSX9885JQ0. We've had it for about 4-5 years now. Never had a problem until now. The machine beeped (as when done with the load) My wife went to put those clothes in the dryer, but the tub was still full of soapy water. She put it in the rinse cycle to rinse the clothes and the motor runs, the tub spins, but the pump is not draining the water. I hear a clicking sound when the motor is running too.
  • 3 more comments
  • jtarms45 Apr 11, 2008
    A little bit of helpful information I got late in the game: My wife told me she could smell "something burning" so she shut off and un plugged the washing machine. After running some errands she plugged it back in, and continued washing another load. Same result on the second load without the "something burning". The machine got to the rinse cycle and after the clicking sounds turned it's self off.
    I have added some symptoms to my washer problem...
  • jtarms45 Apr 12, 2008
    Do you think it's the lid switch if the machine is spinning, just not pumping out any water. I can hear and feel the tub spinning, and hear a motor running (along with something trying to switch from the clicking I hear) It just isn't pumping any water out.
    I don't know if the lid switch is the problem. The machine still spins, only when the lid is closed, like the switch still works...
    OK. I haven't taken the machine apart yet. Is there anything special I need to check for on the motor, I mean any switched need to be tripped or is there a sequence or series of checks with the volt meter?
    Genius:
  • 1,073 Answers
The start stop start stop is caused by the motor trying to come out of the start winding into the run winding and can not your need to find out if the main motor has 120 volts fgoing to the run winding if it has then the motor need sto be replaced
Posted on Apr 12, 2008
  • 2,307 Answers
Try to perform the following test as describe on this link. If the machine works, you might have a defective lid switch.
Check here for more info on the lid switch and other possible failures.
Posted on Apr 11, 2008
    Sergeant:
    Champion:
  • 306 Answers
The pump which drains the water sounds to be faulty and may need repaired/replaced. also check to see if there is a clog in the drainage hole.
    Brigadier General:
  • 6,966 Answers
To my knowledge, most problems such as one you have can be caused by three (3) possibilities:
1. electronic - the activating circuitry that engages the drain valve is faulty;
2. electrical - the drain valve is not opening evening if electronically activated; and
3. mechanical - the drain valve is stuck or the most likely, the drain passageway is clogged.
The last would be your best option and possibly the easiest to correct.
To recap, you hear a clicking sound means that the drain valve opens, you hear the motor, means the drain motor is running, but no water drains out, that only leaves a clogged system.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 1 more comment
  • Louie  Role
    Louie Role Apr 11, 2008
    Additional information.
    I was made to understand that your particular unit uses a single motor as the spin motor and the drain motor. The Whirlpool GSX9885JQ0 also uses a feature wherein water is sprayed back into the tun during the spin cycle. This is accomplished by the spin motor doing double duty as motor for the drain pump. The drain pump goes into a Y splitter. The Y splitter is actually a two-way valve. During the normal spin cycle, the valve towards the spray back (to the tub) is open whilst the one towards the drain is closed. On rinse/drain, the other holds true, the spray back is closed but the valve for the drain opens up.
    I would then suspect that the valve assembly is clogged/blocked. Either that or the valve is defective (unlikely) as most internal parts of this brand are very reliable.
    Cheers.
  • Louie  Role
    Louie Role Apr 12, 2008
    Hi again,
    Your initial post "...but the pump is not draining the water..." and your subsequent post "...smell something burning..." could most probably point to the windings of a solenoid or a small stepmotor. The Y splitter previously described is a two-way valve which could be activated either by a solenoid or a stepmotor.
  • Louie  Role
    Louie Role Apr 13, 2008
    Have you checked the Y splitter (2-way valve)?
Whirlpool calupso FL (over fill) flashes....The manual says the washer will beep every 10 seconds and the pump will cycle one half minute on, one half minute off until the over fill switch is reset or the...
Hello & Welcome to FixYa
FL error indicates flood condition and is caused due to any overfill condition that occurs inside the washer. To clear the display you can press and hold the STOP/CANCEL button. Usually this error is caused when overfill switch trips due to excessive water in the tub. You can also try to clean the drain hose and check the water inlet valve. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine not draining after first wash cycle
Greetings,
If you can open the washer, check the drain pipe cause there is something blocking the water.
The washer's drain function is still working as you can hear it trying.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 21, 2008 | Fisher and Paykel Washing Machines
Spin dryer on my twin tub washing machine does not drain properly. There is water at the bottom of the tub
I 've got twin tub w/machine service is not spinning and draining, can you pls tell me how to solve the problem?
Thanks
Oct 06, 2010 | Samsung Washing Machines
Top load washer about 8 years old- Problem 1 = during the finial rinse/spin the tub will not fulling drain and leaves clothes very wet...had a service call replaced the pump, however stills does not drain...
most likely its the electronic board, easy to change. if you can use a second hand one out of a known working machine- see how that goes- it will probably cure the noise problem
Sep 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
After the clothes have spun dry, a small amount of water accumlates in the tub; generally 1/4 inch or so. Why BTW, I'm not sure that I've selected the correct model. Our washer is about 3 years old.
If draining into laundry tub, chances are water is siphoned back into washer due to laundry tub slow drain.
Very long drain hoses( such as 10+ feet) will also cause this.
Nov 05, 2009 | Fisher and Paykel IWL12 Top Load Washer
Water keeps running into machine when it is done but not into the tub but no water leaking on floor so must be going right out of the drain
water can't run out of drain until the drain pump runs. must be water level continuously rising, but slowly. definitely water solenoid switch problem. pl. open and clean if u can or replace.
Oct 28, 2009 | Maytag Washing Machines
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 17, 2009 | Washing Machines
Oasis washer displays code Ld and wont fully drain
LD means long drain. Check to see if there is something clogging your drain hose. If not remove the drain pump from the bottom of the washer tub and clean it out. Also clean the recirculating pump. That should fix it. if not replace the drain pump.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Whirlpool GSX9885J Top Load Washer Logo
122 people viewed this question
Dan Webster
Dan Webster
prem mathew
