Question about Saeco Magic Cappuccino Espresso&Cappuccino Machine
Saeco Magic squirts water out the wand when brewing
Hi:
My Magic is squirting water out the frothing wand, even when I am brewing the coffee with the wand valve closed down. If I turn it quite hard to close even past the "full close" stopping point I can get it to stop while I am brewing, but otherwise it squirts continuously, and I feel I am losing the pressure needed for brewing to the squirting of the wand.
Any ideas?
Thanks, Steve
  • Anonymous May 31, 2008
    Our machine also squirts water out of the steam wand whilst it is  brewing the coffee, no matter how hard I turn off the steam valve. Running a descaler through the machine briefly helped a bit, but the problem quickly returned.
  • 515 Answers
Hi Steve,
You have to replace the gasket on the steam pin, maybe you have to replace the steam pin to if it is worn.
Posted on Jul 12, 2008
Water from frother keeps coming out even when it's off
Hi
When was the last time you did a descale on your machine? You might have a piece of scale that has gotten under the needle in the valve for the wand. That would prevent the needle from closing and water will continue to flow when the pump is running.
Mar 12, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Delexe water light flashing
The brew unit is blocked, check the shower screen under the red o-ring.
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Steam comes from wand when set to dispense water.
Check the connection to the boiler from the pump, there is no water going to the boiler. Try this test, remove the brew unit you will see a white plastic valve behind it, carefully lift the small lever on the valve(HOT WATER), if water sprays, then the problen is at the brew unit, if no water then the boiler inlet or outlet is clogged.
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
I have a Saeco Magic De Luxe. I am having a problem intermittent
Could be the pump not providing enough pressure to force the water through the coffee. When using beans or preground, can you still hear the pump function?
Jun 30, 2009 | Saeco Magic De Luxe Espresso Machine
We have an Saeco Incanto Rondo sClass. When brew coffee, only about half of the water goes through the brew group and the rest goes into the drip tray. When we try to run steam or water through the wand,...
My SAECO coffee machine is a real disappiontment. We frothed the milk a few times and then the machine started to only warm the milk and provide a small amount of froth. Now the company is trying to tell me it's something I am doing! Not so. It is the expensive machine not working.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Water pump?
If you could brewer coffee or get hot water out of the steam wand then it could be the one way valve on the bottom of the water tank. If you are running the pump output into a glass then it is probably scaled up in the boiler.
Jan 02, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Machine coffee grinds drawer overfills with water
Hi The thumb screw on the brew unit is stripped. If you remove the brew unit and you have water where the thumb screw is its stripped. you just need to remove the old one and replace it.
Oct 13, 2008 | Saeco Magic De Luxe Espresso Machine
Magic De Luxe Frother won't work!
means you do have the hot water button pushed and not just the steam function.
Follow this SAECO
Jun 03, 2008 | Saeco Magic De Luxe Espresso Machine
Brand new Incanto Classic bought online, not working after 1 month
First, machine should be under warrantee- check with 1800myjuicer.com
Sounds also like you have blockage in the steam wand- every time you froth milk, you should let some water come out- to prevent clogging. Try first inserting a pin into steam want ( machine turned off) to see if that alleviates the problem. Also contact
Saeco USA Inc.at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 17, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Magic Cappuccino Espresso&Cappuccino Machine Logo
303 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
