Question about Cameras
I have a canon powershot a560. i would like the date on the pictures. i followed the manual which says turn on date stamp in the menu but it skips over the date stamp so i can't change it. any suggestions?
When you turn your camera on, there is a screen which appears in the viewfinder. Push the FUNC SET button and then scroll down the column on the left of your viewfinder until you come to the one with the letters M1 M2 M3 S, etc to the right. Then select the one called "Postcard 1600x1200" by scrolling to the right. Your camera is then in the post card mode. You can then go to the date stamp in the menu and your camera will not skip over it any longer! EUREKA!!
Posted on Sep 20, 2009
Unfortunately you can embed the date on the image only when using the postcard mode...
Posted on Sep 02, 2008
How do I get the time and date to stamp on my pictures?
Time date stamp only works and is selectable in "postcard" (1200 pixel width) resolution. First select this resolution, then time date stamp should be selectable in the menus.
Jun 25, 2011 | Canon PowerShot A560 Digital Camera
How do I get date and time stamp to display on picture with the A560 Cannon Camera
This function can only be set in Postcard mode- Press Func., scroll down to the bottom, then across to the mountains with clock icon, then set. Now press menu, scroll down to date, and set date or date and time, then menu again.
Nov 30, 2010 | Canon PowerShot A560 Digital Camera
How do I turn off the date and time stamp on my canon powershot sx110?
The menu on the camera controls the date and time stamp. Turn on the menu i camera mode, there are three choices, Camera, Settings and customize. Time stamp should be in the middle menu. Look for time settings and turn it off. All pictures have time and date always. The time/date stamp just makes it visible in the image.
Feb 28, 2010 | Canon Powershot SX110 IS Digital Camera...
How do i turn on the date stamp on my Canon Powershot SD750 so that the date prints on all my pictures?
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
Jan 31, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Cannot turn date stamp on in menu settings.
Date stamp is only possible when you set the resolution (picture size) at "Postcard 1600x1200" option, if the date stamp is set to "Date & Time" or "Date" option
May 18, 2009 | Canon PowerShot A630 Digital Camera
I cannot get a date stamp in my pictures with my Canon power shot A560. I can't get the option to turn it on, it says date stamp off.
In order to get the date stamp on the pictures, the resolution/size has to be set to "Postcard". Look at the menu and you will see L, M1, M2, M3, S, and Postcard. Then you can turn on the date stamp option.
Nov 28, 2008 | Canon Cameras
Canon A540
The date will only show up on the picture under a limited set of circumstances on the Canon PowerShot digital cameras, of which the A540 is one. You've probably found the Date function in the menu, but discovered that it was off, grayed out, and skipped over whenever you tried to reset it.
Date stamp will only work in "Postcard" mode. Press the Function button (labeled "FUNC SET"), then press the down button until you reach the Recording Pixels selection (usually labeled "L", but not always). It's probably the bottom onscreen selection. Use the right or left buttons to select Postcard, then press the Function button again.
Press the Menu button and scroll down to Date Stamp. Now you should be able to select "Date" or "Date & Time" with the right or left button. Press Menu again and take your pictures.
Sep 29, 2008 | Canon PowerShot A540 Digital Camera
Need help
go to function and change pic size to wide or it shows a w -then you will see in main menu highlight of time and date stamp-canon can only do date and/or time in a certain size pic-rember it's a lower quality resolution than normal-change pic size first at bottom of function menu then go to main menu
Jun 09, 2008 | Canon PowerShot A560 Digital Camera
Won't set date and time
Greetings bpm123,
My suggestion is to simply turn the date time stamp off in the setup menu. In reviewing the instruction manual, it appears you can obtain instructions on how to do this starting on page 21.
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 24, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Cameras Logo
505 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
