Question about MSI K8MM-V Motherboard
System restarts after booting into windows
Having a problem with MSI Mainboard. This has happened with the third mainboard of this kind. Eac time windows starts as soon as the welcome screen comes up and theicons appear the system restarts. It works quite fine in SAFE MODE, but as long as is it is normal windows, it keeps restarting. Please Help.
  • proudy Apr 22, 2008
    I have the same problem with a computer I'm trying to troubleshoot for a co-worker. There was a great deal of virus /malware on it, so I did a clean install of Windows, and now I can't get it to boot reliably.
    The second issue is that after starting and stopping the computer 4 or 5 times, it will refuse to boot at all. The fans and HD come on, but no video, and no splash screen. If I unplug it for 15 min or so, then I can start it again.
    I'll try different memory, and see if that helps.
  • 472 Answers
This could be a number of things.
  1. A bad driver is being loaded when Windows starts. Most drivers are not loaded in safe mode so the problem won't happen there. If you have recently added any new hardware, then locate it in device manager and uninstall it.
  2. Bad memory can cause this. Windows running normally uses memore memory then it does in safe mode. If it hits a patch of bad memory while it is loading, then it can collapse instantly.
There are of course hundreds of things that can go wrong at any time..even brand new components can fail or cause issues.
Start with the 2 options above and see how you go.
Hope it helps =)
Posted on Apr 11, 2008
MSI MS-7778 (Jasmine)
Hello it`s right the mainboard is a msi, but the support belongs to HP/COMPAQ.
The mainboard was made by msi, for HP as a OEM product.
There is no driver to be found at the msi site, you have to visit HP here:
And enter the pc`s model number, or sku number from the back of the pc.
Entering the mainboard number does not help.
You probably have to select your windows system, if you need the drivers.
Here is some info about the mainboard:
Hope this will help you
Feb 26, 2013 | MSI Computers & Internet
I have recently installed windows 7 but there is no audio sound i think drivers have not been installed that is why my computer is lack of audio sound to hear a music please make a hand to me i mean h
Hello here is the homepage:
Here is no sound drivers for windows 7.
If i am wrong by the mainboard model, enter the ms xxxx number here:
The ms number is located on the mainboard.
The solution is to buy a sound card, to add on the mainboard.
You just have to make sure, the driver is available for your windows system.
A sound card, can be bought online, or in a computershop.
As i know, MSI is not planning to make drivers, for this mainboard for windows 7.
Good luck
Feb 01, 2013 | MSI K8N Neo4/SLI Motherboard
Vga drivers not working
Hello visit the MSI support site here:
Enter the ms xxxx number from the mainboard, in search for the driver.
When the mainboard is found, click on the download button, and select driver and select your windows system.
Download the vga driver, and unzip the file before you install it.
Good luck
Jan 21, 2013 | MSI Computers & Internet
I want to vga driver
Hello visit msi here:
Enter the ms XXXX number from the mainboard.
The number is placed by the pci socket.
Select the mainboard model.
Select your windows system and download the vga driver.
Unzip the file before you install the driver.
If you can`t find the driver post back a comment and i will help you.
I will need the ms mainboard number.
Good luck
Dec 04, 2012 | MSI Computers & Internet
Hi Mr. Smith,
You cant find that boot disket on internet. Only MSI peoples can help you. Here is the download link for you.
So.. happy download and write everything on a CD/DVD first.
Link :
Mar 16, 2012 | Computers & Internet
MSI P965 Pt Continually re-boots on start-up
You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
Dec 31, 2011 | MSI P965 Platinum Motherboard
Video controller ( vga compatible ) required
Here is an official link for downloading the on board VGA drivers for MSI 865GVM3-V for windows xp operating system. In case thisd is not you op. system you can use this link to choose another one. Note that Windows 7 are not supported, if this is your case you have to try the compatibility option.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Aug 15, 2011 | MSI 865GVM3-V Motherboard
Difficult to boot. I must try 5-10 times or press the mainboard.
When rebooting or shutting down, hold the power button for at least five seconds.
Aug 31, 2009 | HP Compaq nx8220 Notebook
MSI drivers
Hello visit MSI here:
Enter the MS XXXX number printed in on the mainboard:
(This is just an example)
When you find the mainboard select download and the drivers site.
Please select your windows system.
Download the drivers needed and unzip the files before you install.
If you can`t find anything at msi visit the manufactures site of the pc
(not the mainboard) and seach for drivers there.
Good luck
May 21, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
MSI K8MM-V Motherboard Logo
69 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
