Question about Logitech 250 Headset
Bandwidth problems and sound
When i start up or re plug in i have to rest setting of what i am using to chat then it doesnt always work once it does comes up not enough bandwith i have no clue what that means have even unpluged other usb cords and still uses too much bandwdth can you suggest a better headset have had problems with otheres that only use mic and earphone plugs.
  • Logitech Master
  • 13,433 Answers
There probably noting wrong with the headset, there is most likely a problem with the software you are useing.
Posted on Apr 28, 2008
Bad camera view
Step 1:
Whether your holding a video business conference, having a personal video chat with a friend or recording video with your laptop webcam, image clarity plays a huge factor in the quality of the video. There are a number of factors that contribute to the image quality, including available lighting and screen resolution settings.
Adjust your webcam settings, such as brightness contrast, hue and saturation to accommodate the lighting in the room. In order to access your webcam settings, click on "Start" and open the "Control Panel." Choose "Hardware" and then choose your internal webcam from the hardware menu. Select the "Properties" tab to open the setting controls and slide each bar until you achieve the ideal visual settings for your broadcast. Increase the available lighting behind you when conducting a webcam chat, but do not increase the lighting close to the webcam. A lack of back lighting not only creates a darker image projection, but can cause graininess. Too much light close to the webcam can blanch the image, making it difficult to see. Adjust your screen resolution. When the image quality is blurred and distorted during a webcam broadcast, lowering your resolution can sharpen the image projection. To lower your resolution, right-click on your desktop and click "Properties." Choose "Screen Resolution," from the available prompts. Lower the screen resolution one step below where it is currently set and test the image quality. If it needs further sharpening, repeat the process until you achieve the desired clarity. Adjust settings in the video chat program you are using. For example, if you are using Skype, select "Tools" and click on the "Video" icon in the left toolbar. Select "Webcam Settings" and adjust your visual and camera function settings, such as the hue and saturation, as well as lighting compensation. Test your bandwidth settings. If the traffic on your network is high, and multiple users are sharing the same Internet connection, it can affect your bandwidth and lower the quality of your video projection. In order to conduct a quality video session, you should have minimum bandwidth connection of 128 kbps. To check your bandwidth, visit an online test site like SpeedTest and run a bandwidth check. Dust off the lens to free dust particles with an air can. Dust particles can cloud the clarity, but you don't want to wipe them away with your fingers or a rough cloth. Blasting the lens with a burst of canned air will blow away debris and help improve picture clarity.
b>
Feb 22, 2013 | HP Computers & Internet
My webcam is not clear
Hope this helps
Nov 05, 2012 | Computers & Internet
I am using DELL STUDIO laptop with Windows VISTA and recently i am facing issues in voice chat (Yahoo Messenger, Gtalk, Skype etc..). At the time of online voice and video chat we were not able to hear...
Most likely, it's not due to the computer, it's due to bandwidth. Either you're direct connection to the internet, or the bandwidth you pay for from your internet service provider...
1.) So, if you're connected wirelessly, try connecting directly with a CAT5(or 5E, or 6) ethernet cable, that will speed your connection up A LOT.
2.) If you ARE connected by cable, check your download/upload limits set by your internet service provider. If you have only dial-up, it probably won't be fast enough. You'd need at least a DSL or ADSL connection, cable broadband is best.
Hope that helps!
Jan 30, 2011 | Dell Studio 1537 Laptop Computer PC...
I cannot chat voice with my sister but able to chat with another person. what could be the problem
This is usually a problem with bandwidth on her end or with improper microphone or sound card installation on her end. Sounds like your end is okay if you can chat with another person. You can have her click the Help menu in Messenger and select Audio Setup Wizard. Run through the setup wizard and be sure that all of her audio devices are set up correctly. If this doesn't cure the problem, then bandwidth is most likely the culprit.
Good Luck
Gill
Sep 24, 2010 | Yahoo Messenger
My insprion 1521 always asks permission when im using it for, example, good chat. I have two buttons i can choose: allow or deny, but when i click allow, it still doesnt work
It is setting in your anitvirus or firewall to protect your computer. You could add god chat into the trusted site list, it should work.
May 10, 2010 | Dell Inspiron 1521 Laptop
I need to limited the speed of each computer on a network. What is the lowest overall "maximum bandwidth" I should set that will not effect skype video communication (also Yahoo & WLM Video Comm) and...
Video chat (Yahoo, Live, Skype) can function as low as 760kbps, but of course higher bandwidth will give better video quality.
Youtube can work on speeds as low as dialup rates, but it will take longer to buffer enough video to begin playback, so faster speeds will mean faster starts to your video streams.
You shouldn't be trying to do both (skype chat and stream video from YouTube) at the same time and expect the videos to go smoothly. It won't hurt anything, but it won't be good video quality.
Apr 10, 2010 | Computers & Internet
Im having trouble connecting to xbox live. Everything works fine when my sister's are NOT on their laptops. However, as soon as they start browsing the internet, I experience lag (although my connection...
Sounds like there is an issue with bandwidth on your internet connection. Either you have a lot of sisters using your bandwidth, your ADSL connection is on the slow side, or both. Your Xbox isn't getting the bandwidth it requires to operate smoothly.
There are ways to configure your router to allocate bandwidth to connected devices in proportions that you set. You could have 70% and they have 30%.
Also check that they're not watching streaming video or downloading stuff at the same time you play. Alternatively just hide their laptops. :)
Mar 03, 2010 | Belkin F5D8236-4 Router
The internet speed is slow.. connection is in & out
Here's another one.. to take the 20% bandwidth Windows is stealing from you. You'll love it! This guide teaches you to counter one of the main problems any Internet User may face - Slow Internet Speed! As simple it sounds, its as simple to increase it!
addthis_url = location.href; addthis_title = document.title; addthis_pub = 't1ma';
1) Go to Start>Run. Type in “gpedit.msc” (Without the quotes, duh!). (This opens a “Group Policy” window. If you're like me, you wont be interested in what it actually is, but what it can actually do for you.. Right? Anyways..)
2) Follow this path: Local Computer Policy>Computer Configuration>Administrative Templates>Network>QoS Packet Scheduler>Limit Reservable Bandwidth>. If it's disabled or not configured, change the settings like the one below: bandwith.jpg
Like the above screenshot indicates, select "Enabled" and set the Bandwitdth limit to 0%.
Why did we do that? Simple, like I said before, Windows is silently eating 20% of your bandwidth. I emphasize on the word “silently” - The explain TAB of the above window proves it. This is what it says:
Determines the percentage of connection bandwidth that the system can reserve. This value limits the combined bandwidth reservations of all programs running on the system.
By default, the Packet Scheduler limits the system to 20 percent of the bandwidth of a connection, but you can use this setting to override the default.
If you enable this setting, you can use the "Bandwidth limit" box to adjust the amount of bandwidth the system can reserve.
If you disable this setting or do not configure it, the system uses the default value of 20 percent of the connection.
Important: If a bandwidth limit is set for a particular network adapter in the registry, this setting is ignored when configuring that network adapter.
Warm regards,
Anirban Mazumdar
Nov 05, 2009 | Computers & Internet
Clear chat mic doent work
in skype go to tools>options>audio setting make sue the microphone is logitech and the green bars should start moving as you talk.
if no logitech appears or the mic is not producing sound. call logitech for warranty info. if the mic is producing sound below is "make a free skype test call" to see if the program is transmitting.
Jul 18, 2009 | Logitech ClearChat Stereo Headset Headset
Logitech headphones not working with MSN
The internet bandwidth or speed is too low or being occupied by some other programs.Thereby leaving a low speed for the msn to work.The solution would be close some applications using internet or reinstall the msn messenger.
Jan 19, 2009 | Logitech 250 Headset
Logitech 250 Headset Logo
23 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
