Question about Panasonic PV-V4021 S-VHS VCR
Panasonic VCR PV-4652
VCR works fine, both sound and picture, however, the multi-function display on front does NOT work--does not light up--is there a fuse inside that may control this part ?
    Novelist:
    Champion:
  • 275 Answers
If the MFD (Multi Function Flourescent Display is not working, check the -27 - 30 Volt (minus 27V to minus 30V) supply line. The fuse or a fuse resistor (around .5ohms 1/8W ) will be blown.
Also, it is possible that the 3V AC heater supply line is disconnected at some point.
Check that also.
Posted on Jul 20, 2008
We just purchased a Panasonic VCR/TV Universal remote for our PV-V4021 VCR and find we no longer have a user guide. How can we set the VCR to record at a later time, such as later in the evening? Where...
The problem with universal remotes is that unless you enter the correct code for that model not all functions will operate. You need to try every Panasonic code in the code book, untill you find one that works the guide function. Otherwise the only real solution is to get the original remote.
Aug 21, 2010 | Panasonic PV-V4021 S-VHS VCR
Dvd player stopped working
NEED REPLACED DVD MECHANISM UNIT
Manufacturer Panasonic Part Number LSXK0118 Description MECHANISM
Sep 12, 2009 | Panasonic Televison & Video
Can't use VCR
There's nothing wrong with your VCR. Your remote probably set to control your TV. To fix that, simply press the VCR button on the remote, and you should be fine. The "T-U" really means "TV," but the designers at Panasonic wanted to use the standard seven-segment display to cut costs, hence "T-U" instead of "TV."
May 16, 2009 | Panasonic PV-V4022 VHS VCR
Panasonic PV-8400 Remote sensor not working?
This is indeed a faulty IR sensor. If it's just the sensor, swap with your good one to check. From memory they are plug in - a little device behing d the smoked translucent facia (display panel). I have come across this several times with Panasonic VCRs. Check whether the remote works at night time with all fluorescent lights in the room switched off. If so, the IR filter circuitry is faulty. Same solution - replace IR sensor on VCR.
Jul 21, 2008 | Panasonic PV-8400 VHS VCR
Panasonic Triple Play Model PV-DM2799
Since it works then fails it sound like a simple cold solder joint. All TV's can have this problem and it is a simple one, Solder will heat up and cool down at different temperatures, this will cause a small ring fracture at the connection, simply re soldering this will fix your problem.
Feb 20, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Problem with Panasonic PV-7661 VCR-blank screen for DVD function
Video loss could be caused by either the respective cable or output/input connection on related component...accordianman
Feb 11, 2008 | Panasonic PV-7661 VCR
Panasonic VCR stop
unplug for 10 minutes then replug the cord and see it working regards
Apr 23, 2007 | Panasonic PV-V4523S VHS VCR
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Dec 09, 2006 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Panasonic PV-V4021 S-VHS VCR Logo
203 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
