Question about Kenmore Oasis HE 27082 Top Load Washer
Another question... I have been thru the Auto Diagnostics, had to manually advance from C7 to C8 and cannot reproduce the F51 code. Do you think what I have done might have repaired this? I thought about running a Clean Washer cycle because I am not too crazy about have a basket full of wet clothes if this fails. My part from Sears does not ship until April 25th!!! I found a sensor, a wiring harness and the plastic rotor/motor cover from a place that says it is in stock for 80 bucks! I am thinking of buying these parts!!! Any more help would be greatly appreciated. Thanks! You rock!
  • Anonymous Apr 26, 2008
    won"t spin or wash
    President:
  • 878 Answers
Beddy60, you sure got the parts reasonable. I don't think you need the motor cover.When you receive the parts, you can contact me at catriver@npgcable.com. If you need any help putting them in I will be happy to assist you. Catriver.
Posted on Apr 17, 2008
What does the F51 code mean ?
What washer do you have? The F51 code is a failure of the RPS sensor at the bottom of the motor on the Kenmore Oasis or Whirlpool Cabrio.
This can occur if you overload the washer or if there are foreign objects under the washer that prevent the motor from turning.
If you set the water level for a small load but put in a large amount of laundry, you can get the error. If the drain hose is incorrectly positioned in the drain, the fill water can get siphoned and cause the error. Make sure that the basket turns freely when you lift the lid. Items stuck between the baskets or a problem with the basket hub can also cause the error.
If the unit isn't overloaded and the basket and motor move freely, you need to find where the circuit is failing. See this URL for details on tracking the fault: http://www.managemylife.com/mmh/questions/110568-does-f51-code-indicate-washer . You need to measure the resistance on the cables to the control board from several sensors and the motor itself. These tests will lead you to the parts that need to be replaced. If you aren't sure of your ability to do these diagnostics, call for service.
I hope this helps.
Jul 26, 2011 | Washing Machines
F51 & F72 Codes
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Basket Re-engagement Failure.
F then 72 flashes when the basket check routine fails to determine if the basket is re-engaged after being disengaged.
Is the basket floating? If yes, pump out water. See Long Drain.
Does basket turn freely? If not, determine cause of friction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F51 & F72 Codes
May 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Stops in middle of wash cycle and F51 codes keeps flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
I have a a kenmore oasis ld error cod
ld error code is long drain some thimg clogged up pump ,, first check drain hose could be too far down and siphoning,, if not repl/ or cleaned out pump.....
Dec 06, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Hi I got a code message on my washer machine Kenmore Elite Type: 580, model no: 110.27082603. The code is F51, and on the manual it says to "press STOP and press START again. If Code appears call for...
F51 error code is beacause the computer board did not receive input from the motor on the bottom. Unplug the washer, pull the machine forward and tilt the machine back. On the bottom you will see a large white wheel with a silver allen screw in the middle I think it is a 6mm allen wrech that takes it off. Once you remove the screw and drop the white wheel, there will be a large coil of wires with 4 5/16 screws holding it on, remove these scres and drop the coils. On the right hand side you will see a connector with three wires , unplug it. Use sand paper or a scraping tool to clean all 3 male sides of the connectors. Reverse process to re-assemble.
Nov 25, 2008 | Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
117 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
