The printer indicates a paper jam but there is no seeable paper in it.
  • 1 more comment
  • Anonymous Apr 21, 2008
    WILL NOT PRINT
  • Anonymous May 09, 2008
    says paper jammes and there is no paper in it
  • Anonymous Jun 04, 2008
    Pixma printer telling me paper jamed before ANY paper ever inserted in to it.Also tells me when Itry to scan that the printer has a maintanance programme runing.Code 2,114,0, Unable to resolve.Awaiting Canon experts advice.
    Problem Solver:
  • 15 Answers
Could have a bad paper jam sensor located in the area of your paper tray. Try turning the machine on and off and unplug the machine from the wall outlet to tray and reset the machine. If that does not work then your probably need to call in a professional technician.
Posted on Apr 11, 2008
Paper jam indicates but there is no jam
Please try to clean the paper feed rollers.
Mar 04, 2015 | HP LaserJet P2015dn Printer
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
Canon mx310 indicates paper jam but no paper
The printer has several switches in it to detect paper jams. When paper feeds in it trips the first one indicating that paper is present. Another switch further along the feed path indicates that the paper is feeding okay.
Your problem can be a jammed switch (loose scrap of paper), a broken switch, a switch disconnected from the controller board or a possible bad controller board.
One thing you didn't mention was does it respond the same with paper loaded? It might be that the first switch is looking for some and not finding it, so it is programmed to assume a jam.
Aug 25, 2010 | Canon PIXMA MX310 All-In-One Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
Paper Jam is perpetually being indicated. There
switch off the printer
remove the cartridge and try to blow the dust fom the inside of the printer the fit the printer again.the mesage should disapear.
Aug 06, 2009 | HP Photosmart 2575 All-In-One InkJet...
Kyocera 3900dn says paper jam in rear but no jam evident
Usually a printer doesn't lie when it indicates a paper jam, if you have checked as thoroughly as possible and no paper can be found. It is possible that the paper just isn't feeding and a printer will sometimes indicate a paper jam when paper doesn't feed. But if this isn't the case and a jam is indicated as soon as you turn the printer on, one of the plastic jam sensing actuators may be broken or hung up.
Aug 05, 2009 | Kyocera FS-3900DN Laser Printer
HP 4L printer indicates no paper when the tray has
When you removed the paper jam, was the paper torn? If so, did you ensure that you found all the pieces. (Put the piece of paper back together like a puzzle to verify). There could be a piece of paper stuck in the printer that is causing the paper sensor to fail.
The other possibility is that when you removed the paper jam, something became dislodged in the printer. Forcefully removing paper from the printer can cause this.
Jul 16, 2009 | HP LaserJet 4L Printer
150 people viewed this question
jasbo
jasbo
