Question about Phoenix Gold Xenon-600.1 Car Audio Amplifier
Pheonix Gold Xenon 600.1 power problem.
This morning my subs tipped over along with my amp on top because i took off fast and my box isnt strapped down. now when i turn on my power you can hear a high pitched noise that gets lower and stops. this lasts about one second. the power light will not turn on now. I've reconnected everything, the ground, the remote, and the power. i found a pinch in the remote wire and when i fixed that, the amp turned on, but when i turned up my volume it promptly shut off. anyone have any ideas?
  • jrod81089 Apr 20, 2008
    Ah never mind i figured it out. For some reason, the guy who installed my system connected the ground to the frame with plastic right above it and both were held under the same bolt. when my subs tipped and ripped the ground out of the sub, it also pulled the other end of the ground up so it was mainly touching the plastic and hardly had any connection to the frame.
  • 631 Answers
Do your speakers move in/out smoothly if you push on them?
Have you tried disconnecting the speaker wires from the amp to see if it would remain on?
Posted on Apr 11, 2008
No sound from subs
You need power to the amp. If the light on the amp is not on then your amp is the problem. Get power to it.
Nov 10, 2013 | Phoenix Gold Xenon-400.1 Car Audio...
Can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
Jul 30, 2012 | Phoenix Gold Xenon X10D4 - 10" D4...
I have 2 cerwin vega hed 12" subs , whats the most power of amp i can buy two power them both
if you can afford it, get a pheonix gold amp, cerwin vega's are hard hitters and need lots of juice. get yourself a 1500-2500 watt amp, you will be pleased
Jan 12, 2010 | Cerwin Vega HED-12 Car Subwoofer
I unplugged my old subs and plugged the phoenix gold in but there isnt any sound.
what are all the ohms. u can run two 12d2 together but u cant run them all three togeether if u need more help let me know
Sep 24, 2009 | Phoenix Gold XENON 12d2/12d4 X12D2...
Can i hook up a powered 12'sub to a Pheonix Gold xs2500 amp without blowing the speaker
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help.
Aug 23, 2009 | Phoenix Gold XS2300 Car Audio Amplifier
Ok, I have a pair of infinity dual voice coil 12" subs, and a pair of audiobahn quad voice coil 12" subs. Boths sets of speakers can handle 450w. Which set of 12's would be best to hook up to this amp, and...
i recomend you just use the best single woofer in a well built box and that will give you better sound at lower gain volumes it sounds like you have too much junk laying around but to get good bass run your sub at 2 ohms if the amp is stable at that impedence
Dec 16, 2008 | Phoenix Gold Xenon-200.4 Car Audio...
I looked up that amp, it doesn't have a listing for 2ohms x1 but it has 2 ohms x 2 and its at 250watts. For this situation, I would recommend a different amp or different subs. Right now you are getting the most you can get out of your sub/amp combo, if you only have single voice coil subs. Which is common in the mtx preloaded boxes. Either you want an mono block amp stable at 2 ohms or 2 dual 4 ohm voice coil subs. If you got the subs you would wire the voice coils in series so you could get 8 ohms then the subs in parallel so you could get 4 ohms, which would be the best for that particular amp. Good luck.
-Andrew Hawkins
Aug 23, 2008 | Legend LA1490 - American Legacy Series 2 -...
Phoenix gold ms2125 amp blown?
The following is a forum dedicated to PG amps. Someone there will be able to suggest a tech that's familiar with the amp.
Let me know if you have any other questions.
Aug 18, 2008 | Phoenix Gold Limited Edition MS2125 TA...
Phoenix Gold Xenon-600.1 Car Audio Amplifier Logo
141 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
