Well this has happened to many people before, me being one of them.
I was looking for ideas on the internet and a VERY clever person said to get a thin piece of card and put sticky tape onto it in a circle so its double sided and slide it in so that the memory card can come out! BRILLIANT!! I thought it wouldn't be strong enough, but it was, saved my life. Hopefully it can save yours. xo
This post was brilliant. I had this issue. I took a piece of paper and stuck glue to it on 2 ends and pushed it in the memory slot such that the glue is inwards and touching both sides of the card. I left itin there for 2 minutes and then pulled the card out. It came out in a jiffy.
SOURCE: Picture card stuck in slot upside down
Pry out with a needle like tool from the side: half mm each time. Pry from the left side (thin side) a little bit then on the right, you may need a lot patience until you pull it out. You would pull much better if you had some surgical suturing forceps with the tiny teeth on them.
my memory card is stuck in my kodak easyshare c340
