Question about LG enV VX9900 Cellular Phone
Lg env my phone all of a sudden wont take a charge i try to plug it in and...nothing. the battery is completely dead and has no more power and it wont charge help!
  • 3 more comments
  • funkymonky Apr 11, 2008
    im completely clueless
  • funkymonky Apr 12, 2008
    that is not a solution!
  • Anonymous Jan 08, 2009
    saaaaame issue. and this is my second env, the replacement for the last one.. i just got it less then 2 months ago. lg and i do not get along well.
  • Anonymous Feb 20, 2009
    Well, my phone wont accept the plug that I put in my phone.
    This is my first enV and its never did this before.
    any reasonn whyy thiss happened?
  • Abby Greenwood
    Abby Greenwood Jul 05, 2012
    My LG Vm670 suddenly went off I guess and will not come back on..I know it has power...and the battery shouldn't matter if it is plugged into the charger as they told me at LG
Yea i had the same problem too.
1st of all you probably have a dead battery meaning it wont hold a charge and 2nd your ciruit board where u plug the charger in is probably broken. you will know if its broken if you can wiggle it around, its suppose to be stuck in place.
so take it in to verizon, they will help you, i got a free phone out of it =]
Posted on Apr 14, 2008
I have the same problem
it's so frustrating!
Posted on Apr 11, 2008
My ENV Touch has horrible battery! I will charge it ovenright (8 hours) and it will say charge complete. But then i will unplug it, and when i start texting or go to the camera , it goes down to 2 or 1...
Your phone is charging just fine. It's the battery that is to blame. Purchase a new battery from your choice of local vendors and the problem will be solved. Also, try not to charge it (With the new battery) until the charge is low. This will help prolong battery life.
Jan 25, 2011 | LG enV Touch VX11000 Cell Phone
I have a dead battery in my lg envy and my charger wont charge my phone but that same charger will charger my sisters phone. How can i get my phone to charge?
try your sisters battery on your mobile. if it powers up and your charger isnt working on your mobile then you have an internal loop fault in the power section of the mobile that directs power to charge the battery. its a big fault and is far cheaper to replace the phone than to have it repaired.
sorry
take care.
Aug 03, 2010 | LG enV VX9900 Cellular Phone
LG enV touch keeps shutting off when charging
I would replace the battery and see if that helps with this problem
Mar 30, 2017 | LG enV VX9900 Cellular Phone
Phone went dead. charged it. charge complete. wont
try taking battery out for 30 seconds,then put back in!?
Oct 18, 2009 | Cell Phones
Phone stuck on verizon screen
turn the phone off and take the battery out and immediately put the battery back in the phone that usually works on mine
Jul 23, 2009 | LG enV VX9900 Cellular Phone
Can't turn on LG Phone (Believe it's in the 8600 series)
did it get wet? If so take it apart and battery, put in bag of rice overnight. Try it again. If that doesn't work often the sticker on the battery turned from white to red and if you find a battery sticker it'll work.
Jul 03, 2009 | LG enV VX9900 Cellular Phone
LG ENV TOUCH IS FROZEN. WON'T POWER DOWN, TRIED
You should try taking out the battery for at least ten minutes then putting it back in.
Jun 27, 2009 | Cell Phones
Will not complete charge
Your battery could have a dead cell take it into the store and have them test it. batteries die too if you use music, im, navigator a lot, it will run it down quick
Jul 31, 2008 | LG enV VX9900 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Mar 21, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
227 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
