Question about Canon PIXMA MP780 All-In-One InkJet Printer
Hey got a problem with installing the cartridge back to its holer....
I took off the cartridge,, and refilled,,and so i put it back to its holder but suddenly.,it says i cant print coz the cartridge is not being installed properly and couldnt be detected and so i do it over and many times again it still says the same .....so y is that ??????? pls help me asap its a pixma ip1880..
im desperate....
  • 1 more comment
  • acezai Apr 11, 2008
    ok thanks ill check it out....
  • ink install Jun 16, 2008
    i cannot install the ink cartridge into the printer ip1880 cause no guides are correct supply to me help!
  • rakeshburman Jun 20, 2008
    I have canon pixma mp780 all in one
    there is a error is displayed i.e. wrong cartridge.
    I have replaced the cartridges but the problem is continues......
    pls help.
    Problem Solver:
  • 15 Answers
This problem occurs not just to you some cartridges you cannot refill because they have a chip in them. It might allow you to print a small print job at first but it detects that the chip has not been replaced in the cartridge. You probably need to try replacing your cartridge.
Posted on Apr 11, 2008
I am trying to print a page from my printer and the printer is telling me that the left cartridge is incorrect. and then I get a message on my computer telling me that the cartridge installed is not...
Some times the cartridge holder is dirty take a lint free cloth and very easy wipe it off and try again.
Also if you got refurbished or refilled ink cartridges this can cause a incompatible problem. if they are not recycled clean the holders and put them back in and tell the printer it is new ink even if it is not,where it says is this a new cartridge or a used one check new. hopeully this will solve your problem
Good Luck
Apr 11, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
I was printing on my printer with no problem when in the window of the printer it shows cartridge error,error 1203.I checked the cartridges and they look fine.I took them out and put them back in I...
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink works very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it works for you. Good luck......
Oct 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
My hp deskjet f4288 suddenly stopped printing. so i refilled d cartridge(818) and replaced it. It wasnt printing still. I replaced a new cartridge in its place and the printer was working fine. Seems...
you can simply refill the 818 cartridge first you take the cartridge and then you must clean outer surface of the cartridge with a cotton cloth then fill the ink with a cyringe before you put into the carriege holder you must clean the inside path of the carriege holder then put it it will work very fast and perfectly.
Jan 12, 2009 | HP DeskJet F380 All-In-One Printer
SAMSUNG CLP-600N YELLOW CARTRIDGE DUMPS INK
Did you replace the cartridge with a genuine samsung cartridge or is it a refill or remanufactured cartridge?
Gremlin11
Dec 11, 2008 | Samsung CLP-600N Laser Printer
Refilled cartridges
Walgreens had gave me the wrong print cartridges back. They had my info on them but they belong to a HP printer instead of a Lexmark. We took them back and had to go thru a lot to get them straighten out. My cartridges were nowhere to be found so I'm sure the HP customer will be looking for their cartridges also. From now on no more refilled cartridges for me. Lexmark only! Thanks for the help.
Aug 14, 2008 | Lexmark Office Equipment & Supplies
Wrong Black Cartridge installed error message
Use original cartridges. Nowadays some companies resort to this cheap trick wherein if you put refilled cartridges, the printer wont work, giving errors and does allow you into head alignment tool..
Best bet is to use original inks.
May 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Refilled Cartridge
How can I Reset Memory For Lexmark X4550
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
My Hp does not recognize my color cartridge?
Sometimes the color bleeds over. Did you wipe down the contacts and clean the heads? Also, most of the cartridges have low ink sensors in the. Even if you have them refilled, they will still show as low ink. The only solution is to buy the new ones.... $$$$$$.
Dec 12, 2007 | Dell 922 All-In-One InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
29 people viewed this question
old marine
old marine
