Question about Panasonic PV-GS150 Mini DV Digital Camcorder
Same problem - no playback
Did you find a resolution??
  • CRas Apr 11, 2008
    I was actually replying to someone else's post, so maybe this doesn't make sense -
    I have a Panasonic-PV-GS150 -- about 2 years old. Suddenly, it won't playback anything. Seems to be recording, but cannot play anything back. It's almost as though it's a foreign tape or something in it. It sounds like it's going forward and backwards as I push the buttons, but there is no recording data (date etc) that shows up, and the screen stays blue. As though there is nothing to playback. Thanks!
  • CRas Apr 11, 2008
    I am not trying to use the wrong type of tape. I am not receiving any kind of message regarding dirty heads.
    Thanks
    Genius:
  • 1,447 Answers
Can u pls specify the issue that your having with your cam.. thanks
Posted on Apr 11, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 11, 2008
    If you attempt to play back file recorded in a
    different format or file data is defective, the
    whole display becomes bluish.
    Pls try using a different format of image.
    hope this help
    If the heads become dirty, “NEED HEAD
    CLEANING” appears during recording. During
    playback, moreover, the following symptoms
    appear.
    ≥Mosaic-like noise appears partially or the
    sound is interrupted.
    ≥Black or blue mosaic-like horizontal stripes
    appear.
    When normal playback cannot be performed
    even after the head cleaning
    One possible cause is that normal recording
    could not be performed because the heads were
    dirty at the time of recording. Clean the heads,
    and perform recording and playback again. If
    normal playback can be performed, the heads are
    clean. Before an important recording, be sure to
    conduct a test recording to make sure that normal
    recording can be performed.
    ≥If the heads become dirty soon after cleaning,
    the problem may be the tape. If so, try another
    cassette.
    ≥During playback, the picture or sound may be
    interrupted momentarily, but this is not a
    malfunction of the Camcorder. (One possible
    cause is that the playback is interrupted by dirt
    or dust that momentarily adheres to the heads.)
Poor quality playback on video
hi Frank,
Please try different video file.
and convert it to compatible format with high resolution and give a try.
regards,
nuwan
Jan 20, 2014 | Samsung Exhibit II 4G
HOW TO UNLOCK REGION CODE FOR LG MODEL RC897T DVD/VCR COMBO
The second post seems to supply a solution.
http://www.videohelp.com/dvdhacks/lg-rc897t/9605
"Region code posted by blueskip, August 17 2007:
Click the HOME button on the remote with the unit in 480i resolution
Click the setup page
Click Start
Click TV Aspect
highlight the 16x9 wide aspect ratio
enter on remote control this coded sequence:
1397139
Edit specific "Options"
Option 2: 35 (enables Divx/Xvid playback)
Option 4: ff (enables Vcd and SVCD playback)
Option 5: ff (enables region free playback (region 0) DVD playback)
Option 6: ce (enables Insignia brand startup logo on boot)
Option 6: c0 (enables LG brand startup logo on boot)
nicemarmot adds: must power down after enabling region free playback and
re-start."
Jan 29, 2012 | Televison & Video
Hi,i actualy bought an aoc 2243fw2k led monitor,i hav a nvidia geforce 220gt graphic card,even though i installed the latest drivers for both graphic card n the monitor,i stil cant experience high...
1920x1080 resolution is the starting point for HD video. If you have set your desktop resolution to that or anything avove then you should be running at HD resolutions. Maybe the image/video you are watching is not at a HD resolution, therefore it will appear distorted and streched (poor quality). To fully experience HD playback use video files and imaged that are at the 1920x1080 resolution and above.
Dec 16, 2011 | Computers & Internet
What is the screen resolution to the sharp 32C540 ?
480i is the highest resolution of your tv. The tv has composite, s-video and component inputs in the back. The manual states that with component connections are dvd compatible allowing you to enjoy the highest quality image playback than using s-video. Dvd's resolution are 480i or 480p. I'm guessing it's more 480i than 480p since the tv is a crt tube tv and does not have any of the digital inputs for higher resolutions.
Jul 06, 2011 | Sharp 32C-540 32" TV
I have a LG DVD player model RC 897T, bought in US and supposed to be used in Brazil. It does not read all DVD discs, due to a possible region problem. How can I unblock this device to watch alll...
Click Start
Click TV Aspect
1397139
You must power down after enabling region free playback and
re-start.
Feb 28, 2011 | Televison & Video
Samsung 920WM monitor - Color problems, "blotches"
The 920WM has a recommended resolution of 1440x900. If your display properties are set to a higher or lower resolution, there will be ugly effects on videos, photos and fine text.
If you're running WindowsXP, minimize your apps and web browser so you can see the background.
Right-click on the background and select "Properties" to bring up the display properties dialog.
In that dialog, select the "Settings" tab to see the display resolution.
Set that to 1440x900 if it's not already, then hit "OK"
If videos are still blotchy, then check the video playback software to make sure it's not setting it's own resolution.
If that helps, please be sure to hit the "thumbs-up" button for me.
If not, use "add comment" to fill in some more details (XP or Vista? What's the video playback software called? How are you viewing pictures?) and I'll do my best to help!
Jan 05, 2010 | Samsung SyncMaster 920WM LCD Monitor
Is there a way to change the resolution setting on my fujifilm finepix s2000HD?
Push the F button, it's to the right from Playback button - you will find resolution settings there.
Tom
Nov 17, 2009 | Cameras
How do you get to use a lower reso;ution ie fit
Press the F button on the right from the playback button - you will find resolution settings there.
Tom
Oct 15, 2009 | Fuji FinePix S1000FD Digital Camera
How do I change resolution On Fuji S700 Fine Pix?? Camera now set at 72 dpi , need 300 dpi.
Hi!
If I remember it right, the resolution setting were under F button on the back panel, on the right from the Playback button.
Please, let me know if I'm right. :)
Tom
Jul 30, 2009 | Cameras
Panasonic PV-GS150 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
