CAN YOU TAKE A NEW COIL THAT HAS NOT BEEN USED BUT WAS BOUGHT FOR A CONDENSING UNIT SEER 13 R22 AND PUT IT ON A CONDENSEING UNIT FOR 13 SEER 410 A
  • 4 Answers
Thats a big negative
Posted on Apr 15, 2008
Purchased Rheem 4 ton 16 seer AC installer just left
Ask your installing company for the AHRI number. If installed with a
matching furnace and coil as listed in the certification then you will get 16 seer rating. If they installed something different than what is listed in the certificate then demand all parts listed or a refund.
Jul 18, 2014 | Rheem 14AJM49A01-RHLLHM4821JA 4 Ton 16...
Why does my gibson js5bd042ka keep freezing up
Because your unit is low on refrigerant, air filter needs to be changed, your evaporator coil is dirty, the ambient temperature is to low, or you blower is not running
Jun 05, 2014 | Gibson JS5BD042KA 3.5Ton 13 Seer R22...
Had heat pump replaced roughly a month agoworked fine until yesterday.the wife says it was 85 degrees on the thermostst when it was set at 78. Told her to check breakerfreon line at air handler and...
call the install company back out. along with the new heat pump i wouls say they installed a leak. you stated r12 i assume you ment r22 if they installed an r22 unit and didnt change the a coil it might not be their work leaking but the a coil might be. at any rate once you have them fix it i would look for a new service company i would never install an r22 system any more the EPA is phasing it out and the replacment in my opion is beter
Jun 26, 2010 | Goodman CLQ36AR49 Air Conditioner
Totally not working for our upstairs. The upstairs same unit work
You did not say what the problem was diagnosed as but I suspect that your service technician is going to change the compressor and dryer. This unit even only 7 years old is a R22 unit which cannot be sold anymore. It is also only 10 SEER where new models are a minimum of 13 SEER (produces 13 Btu's per kilowatt). If you installed a new unit the coil in the duct will need to be replaced along with the outside condenser. If the cost of a new one is $1000 or less over the cost of repair, I would go with a new system.
Jun 16, 2010 | Weather King 10AJA3001AH Air Conditioner
I have a bryant 24-567c condenser. need replacement
you have a 3.5 ton unit.The evap will work with a new unit but it will not have the 13 seer performance that the new condencer with matching coil will give you.It is getting and harder to find the old 10 seer units check ebay and craigslist.
Aug 18, 2009 | Carrier 38CKC042 Air Conditioner
Is a goodman gsc139421ac a heatpump
13 seer 3.5 ton unit check inside condensing unit for reversing valve. Also open panel and see if it has a defrost board. It is located above the contactor. Rusty
Jun 04, 2009 | Heating & Cooling
Coil blew up on outside unit, is it better to fix or replace whole unit?
Depends on where the coil is leaking. Also the age of the unit. If it is just a small leak a serviceman can repair it. You have to look at how much it will cost to repair, And the cost of new unit.. The new unit will be a 13 seer and may not match the inside coil. . Also some Companies are selling 10 year parts and labor warranties with new units. Look at the leak on your coil to see what caused the leak. Most of the time it a rubbed line or drier leaking. If you have to cut away fins. Buy another condensing unit. When you cut away the fins you loose heat conductivity. Higher head pressure could cause damage to unit. Rusty
Jun 03, 2009 | Weather King 10AJA6001AH Air Conditioner
Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to replace...
at 5 yr on goodman unit rhe comp should of been under warrenty if theat is what was bad with it on the rudd that was a 3.5 ton out door unit are you sure the pump is bad pulling locked rotar amps or shorted to ground check the wires on the comp to make sure not burnt check the capicitor as far as replacement i always lean twoards new unit unless not going to live there long due to comp is 1 yr and labor around 850 +325 for pump i would go with another used unit over comp replacement 13 seer goodman w 99yr pump and latley have 5 yr free labor and I normally dont recommend a brand of unit on this site go to a hvac store and ask who may have a used unit I have had some still w warrenty before that came from remodel jobs in up scale areas! if helpfull rate me good luck
May 12, 2009 | Ruud UAKA042 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
