Question about Memorex MT1134 13" TV
Programing channels I can not get all my cable channels on tv. channels stop at 22 . i have 98 basic cable chanels.
  • HelenMM Jan 08, 2009
    I have the same problem, how do I set it into CATV?
  • Anonymous Feb 08, 2009
    can't turn my Philips pl0127c121 tv to channel 3
  • 54 Answers
Check your tv set, set it on outo program scan set it into CATV.
Posted on Apr 11, 2008
The TV works however I cannot get the set to read the channels. I have cable but no cable box. Have tried to program it for over 3 hours. I've tried it using ch.3 and ch.4. through the remote. After I scan...
U used the tv remote go into ur tv SETUP.Pick Cable,before u scanning for cable chanels?U have pay cable?Must scan for cable chanels,by setup for looking for cable channels.
Mar 18, 2011 | Televison & Video
I have a brand new straight from box LG TV model 32LD320. I have unpluged the HDMI from old TV ( where was working 100% OK) plugged into new TV. Mains switch on - and cannot get any chanels to report on...
HDMI sends video from a source likea bluray player or 'cable box' to tv it will not send signal so you can program channels from it
turn tv to the HDMI input you plugged device into and watch cideo from that source
you will need to connect some type of antenna to be able to program channels on tv
very few tvs need channels programmed these days since most people hook up a cable or sattelite receiver and change channels that way
hope this helps if not give me more speecific details and i can help you more
good luck
Mar 13, 2011 | LG Televison & Video
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
My tv is attached to a cable inpt but no cable box i am able to watch all cable channels by switching tv chanels,is the inpt digital or analog
The signal you are viewing is an analog signal.
The cable companies take the signals for your basic channels and resend them through the cable as analog so the customers that still plug the cable direct to their TV can still get some programming without the added costs of digital cable boxes on every TV.
This option will be slowly phased out over time but for now it is available.
Jan 08, 2010 | Sharp 13N-M100 13" TV
My 60'' LXI slimview television will only save one chanel.
If you have remote control for the channels on your set, try to push menu then choose "memorize channel" or choose "cable" then do the channel memory.
Thanks.
Aug 16, 2009 | Televison & Video
I have an old, jvc 20 inch, c2010 model tv without the remote and I am unable to place channel on 4 so it will be compatible with my digital comcast cable box. Any suggestions?
I hope you are able to get into the menu with the front panel.
when you are in the menu you want to be able to make the auto-programing feature works. The cable box has to be already installed and working. when the tv programming crosses the channel 4 and there is a signal there, pretty sure is going to look it. This is the easiest.
The other solution is the menu sometimes allows you to make programming manual. in manual you are able to search channels one by one and allow it in the memory or not, basically then go to manual programming scroll up or down to find the channel four and use enter (sometimes right arrow in order to change the chanel number from red to green) to record in memory this channel. Once again I hope helps you.
Apr 14, 2009 | Televison & Video
Program channels
Just Press Menu> scroll or Navigate or Select Auto program, then press enter> (to Move press volume button -minus or +plus,and to enter or OK press TV / VIDEO) then select auto program to automatically scan channel. Choose Air if you use outdoor antenna,if cable choose Cable,whatever the result ,just post so i can assist..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I am having difficulty when I try to program the VCR to tape a TV show that I am not watching. When I go through the nine steps that are outlined in the manual on pages 24 and 25 the TV will tape for me...
if you are useing a cabel box you need to split your cable before the cable box with a two set coupler and run the second cable line to the VCR input and this should solve your problem. if you want to record the chanels from your cable box and not watch a diffrent chanel you can leave it hooked as is and select the chanel you want to record with your cable box tunner and leave it turned on, set the vcr to record channel 3 or 4 which ever is the channel you leave your tv tunner on and record that way.
Jul 30, 2008 | Televison & Video
We have basic cable that goes upto 60 or so channels, but one of our household televisions only shows upto channels 13
First make sure how many chanels the TV itself has.. Some TV's (usually the smaller 14" old CRT's) dont hold that many chanels..
May 21, 2008 | Panasonic Televison & Video
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Memorex MT1134 13" TV Logo
231 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
