Question about Whirlpool GS460 Gas Kitchen Range
Oven will not stay lit,
The broiler will stay lit however the oven with a little help will light, burns for about 5 seconds and then goes out....
  • Anonymous Mar 14, 2014
    Oven lights but want stay lit
  • 32 Answers
Sounds to me like a bad thermal fuse. Call a tech in to replace it.
Posted on Aug 20, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Avanti G2002CW oven or broiler won't stay lit once ignited
I had this same issue on this same model (which is how I happened upon this page). I'm still not exactly sure why, but the problem resolved when I pushed down on the knob more firmly than I normally would to light the stove, and it seemed to slide in a little deeper. After that, the oven would light.
Jul 07, 2013 | Avanti Kitchen Ranges
My Magic Chef model 9112XUB wall oven will not light. It has power and gas but will not ignite.What can I do to fix it myself?
If this model has electronic ignition, you can open up the broiler door , turn on the oven, and look to the rear of the broiler...there should be a sort of glow plug getting reddish/orange. If not, the oven won't light and you will need to obtain an ignitor for the oven. these are available through appliance parts distributors such as Bell Parts Suppy. If it is a standing pilot model, then first check to see if the pilot is lit...if it's not lit try lighting...if it won't stay lit, then the thermocouple is probably bad and will need to be replaced
Dec 19, 2010 | Magic Chef 31100 Gas Kitchen Range
My electrolux oven won't stay lit
Right above your pilot light, there is a little temperature probe. It either needs to be cleaned, replaced, or adjusted closer to the top of the pilot flame. Hope this helps. Good luck!
Nov 07, 2009 | Cars & Trucks
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven and broiler: no heat
Flipped the breaker switch! Although we had looked at the breaker first thing, and it was not flipped off, plus everything else on the range was working: we found out it is actually a double breaker, with one half controlling just the oven, and it can be just partially flipped and you don't notice it. So as soon as you toggle it off and on again, you are back in full power.
Apr 08, 2009 | Kenmore Kitchen Ranges
Amana gas oven will not stay lit
i'm having the same thing happen to me however the broiler works fine.
Nov 17, 2008 | Amana ACF3355 Gas Kitchen Range
Oven, broiler don't work
The main control board is what you need to replace here.Please Rate This !
Jul 06, 2008 | Kenmore Kitchen Ranges
Broiler glow bar stays on
the glow bar stays on in gas ranges the whole time the cycle is running if it didn't the safety valve couldn't open its normal
Jan 20, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Whirlpool GS460 Gas Kitchen Range Logo
650 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
