Question about HP Photosmart 335 InkJet Printer
Cleaning my printer
I'm lookig for a diagram of the inside of ahp photosmart printer.Need to but a brush back in but forgot how nit goes back in after i cleaned it.Help
Teresa
  • vhronnie Nov 30, 2008
    I just put in a new print cartridge and it just continues to blink off and on with an error message of 07A74DD6!
Never buy another HP product again!
Posted on Dec 02, 2008
HP Photosmart 2610 all-in-one printer. I've replaced my color and black carts. with refilled ones. My color ink drained all over the bottom of the inside of the printer. I am no longer going to be...
You can use a degreasing spray or methyl alcohol to clean up the residual ink. Use a brush to clean and wipe and BLOW using a hair dryer to fully dry up the residue.
Make sure that there is no dirt at the terminals, clean and set with original cartridges from HP.
Now if there is errors then you must disconnect printer, uninstall then install the driver, connect printer when prompted and print a test page.
Sep 05, 2011 | HP Photosmart 2610 All-In-One InkJet...
The paper feed on my hp c6180 all in one photo smart printer does not operate. Top or bottom feeds. I have already checked for paper jams.
This is sort of scenario is usually causedby dust inside the printer. Dust has a way of preventing the sensors fromdetecting paper. Also it prevents the rollers from having a firm grip on thepaper while picking paper. Sometime one side grips well and tries to pick thepaper while the other doesn't resulting in a jammed. I will suggest you get along handle brush and try to reach as far inside the printer as possible andbrush (from the back and front). If you have a blower you may also use it toblow well into the interior of the printer (Ifyou do not have a blower the brushing will still do if you do it well.) This,if properly done should do it. Brush especially the rollers etc. Good luck & God bless!
Nov 30, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP 3180 all in one printer gives error that paper is not present, yet tray has paper. Check paper light blinking, and E in printer display. Performed "hard reset" as shown on HP website, does not help.
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Oct 21, 2010 | HP Photosmart C3180 All-In-One InkJet...
Printer takes in paper then fails to print and reports a jam.
Hi
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | HP Photosmart 7450 InkJet Printer
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
The printer won't print, it's trying to pick up the paper inside
Pull out the paper tray, at the front of the tray, there's a translucent roller in the middle. Remove the roller and clean out any waste paper dust inside & wipe clean the roller before putting it back.
Dec 10, 2009 | Brother HL-2040 Laser Printer
It always says "out of paper" even if theres paper in it
scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). After blowing, if you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Dec 08, 2009 | HP Photosmart 3310 Printer
I am getting an Error "remove and check cartridge on right". I have changed the cartridge. I have cleaned the sensors on the cartridge and where the cartridge goes into the printer. What else can I do?
Remove the cartridge and look inside where it goes, sometimes the spring on the right comes loose and tears the ribbon cable in the back. If that has happened you will need a new carriage assembly, hard to find, expensive.
Jul 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
How to put ink in ahp photosmart 1215 printer
Hiya
Just above the paper slot there is a flap that opens, The cartidges go in there,
Hope this helps
Oct 18, 2007 | HP PhotoSmart 1215 InkJet Printer
HP Photosmart 335 InkJet Printer Logo
Seeker5211
Seeker5211
