How do I Cancel a wash cycle? I have no manual and tried the reset button but nothing happens. I accidentally started an empty dishwasher and would like to stop it. I have the door open so it won't run but it keeps beeping to remind me it is set to run. HELP! Thanks.
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
