Question about LG LRBN20510WW Bottom Freezer Refrigerator
LG Bottom Freezer problem with ice
Where is the drain hole that needs to be unclogged?
    President:
  • 1,314 Answers
Its behind the freezer back panel cover under the evaprator which looks like a silver honey comb
Posted on Apr 12, 2008
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
Mar 12, 2016 | LG Refrigerators
Plugged drain
Need to completely defrost freezer. hot rags, hot water, paper towels, etc. Until you get all the ice out you don't have a chance of unclogging the drain. Could be just ice clogging it too which in that case hot water will solve that as well. If it's something else clogging the drain, I've used a mini bottle brush to unclog them or even a stiff piece of solid wire.
Mar 18, 2013 | KitchenAid KFCS22EVMS Stainless Steel ...
Whirlpool mod#et18pkxgwu top freezer,no ice maker. water leaks from freezer down intt the bottom ver. bins.
The Water is coming from the defrost cycle melting the ice on the evap coil.  There is a drain that goes to a tray near the compressor where the heat from the compressor evaporates the water.  That drain is clogged.  Take the back panel off of the freezer and unclog the drain hole.  Most of the time it is iced over and the ice needs to be melted.  It could also  be clogged where it comes out at the compressor.
Oct 25, 2009 | Refrigerators
My GE TFX27PF fridge is leaking water out the bottom.
You will need to remove the food from the freezer .Remove the lower shelving and the 6 screws holding the lower rear freezer panel on . At the very bottom , below the coils , you should see a drain hole . If not , and you see ice , then this drain hole is clogged with ice . Use a hair dryer and hot water to defrost the hole . Use a small tube , inserted into the drain hole , to blow out any unseen debris , which will clear the drain line . Reinstall in reverse order .
Oct 14, 2009 | GE Refrigerators
The bottom of my lg french door bottom freezer freezer has a layer of ice
Hi, The defrost drain is plugged. UNPLUG the refrigerator. Remove the rear inside panel in the freezer section and locates the drain hole below the evaporator coils. You will have to melt the ice in the drain hole and flush it out with hot water.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
Freezer Coils icing over
Drain clogged.
Directly below the coils is the drain. You may have to use a hair dryer to remove the Ice so you can see the drain hole but it's there. Once you unclog the drain all that water should go down and into a plastic pan under the Ref. Heat from the compressor will evaporate the water so, you should never have to empty this pan.
Jan 24, 2009 | KitchenAid KSRS25IL Side by Side...
Leaking water
dianaluscou,
The freezer has a drain hole in it typically in the back at the bottom. This is clogged and needs to be cleared out in order to stop the water problem in the refrigerator section. Remove everything from the freezer and if needed defrost. Look for the drain hole and you can pour hot water or use a hair dryer to melt the ice in the drain. Once it is unclogged, the water problem should stop.
I just did this about 6 months ago on my own refrigerator/freezer.
Cathy
Jan 21, 2009 | Frigidaire FRT21P6BS Top Freezer...
Water drains internally at back of freezer drawer
Check the drain.
Take the bottom drawer out of the freezer and look in the very back for a drain hole. It may be covered with ice. A hair dryer will melt the ice so you can unclog the drain.
Dec 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Water leaking from bottom left freezer/dispenser side
Take the metal back panel off the inside of the freezer, exposing the cooling coils. Below the coils, at the very bottom of the freezer compartment you will find a small drain hole. (Presently covered over with ice) Use hot (not boiling) water and a turkey baster to melt the ice and force hot water into the drain hole until the water runs out the drain hole (and into the defrost drain pan under the refrigerator) on it's own. This should be a Fix-Ya for your refrigerator.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LRBN20510WW Bottom Freezer Refrigerator Logo
325 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
