Question about Acer TravelMate 2300 Notebook
Acer Travelmate 2201LMi
Hi there.
Two issues really.
1) My dvd/cd unit will run with original discs including my xp set up, but will not read my own music discs that I have recorded. It's ok if I reinstall XP from fresh, but after a few hours it fails again.
2) When I select My Computer on the desk top, then right click for instance on drive C, this part of the system stops responding. So I cnrtl+Alt+Del to End Task, it shows My Computer Not Responding, it goes through the process successfully to end this process & comes back to my desktop successfully too. It locks up every time I try..
I have to use Start, All Programmes, Accessories, Command Prompt, if I need to format a floppy disc.
Any ideas please
Yours CT. Leeds
  • 1 more comment
  • Chippietom Apr 11, 2008
    Chippie Tom again. I did download as suggested but still not working I'm afraid. Player stops responding when I try to read photographs, there's a noise which implies it's trying to do something but then jumps back, tries again, and jumps back, etc, etc, with the usual Not Responding message. But thanks anyway. Yours CT
  • Chippietom Apr 12, 2008
    I have 1.2 gig of memory so I'm still not sure what it is, thanks anyway gents/ladies
    Ilooked in system, no CD mentioned within system info conflict/sharing. Not an Interupt Request (IRQ) conflict either. No forced hardware.
    May I point out that when I was listening to my radio-headphones many months ago, this was whilst I was trying to get this CD player to work in order to view some images I'd burnt on a cd, that I heard a slight crackling sound, almost like a very feint loose connection arcing sound, the sound of electrical wires/connections arcing. I stopped the CD/DVD player from trying, and the arcing sound ceased. I repeated this, and the arcing returned, and stopped etc. Don't know if the makes sense..Perhaps a dry solder joint or loose wire?? I'm still none the wiser but again, Thank's CT
  • 520 Answers
Theres no prob with ur cd the prob is the software(usually codecs) download a program(media player)called vlc.just type vlc in search engine.
it can play every file youve ever heard of;comes complete will all codecs and its free.
for the other prob check device manager and look fro question marks or red crosses.
it could need updating or you may not have administer permission.
Posted on Apr 11, 2008
  • tat4u
    tat4u Apr 12, 2008
    ur problem then could be memory related.unless you have upgraded mem I think the acer has only 256 ram and windows takes a big chunk off that and then another big chunk is assigned to the graphics leaving very little for applications.
    vista wont even install with anything less than 512 ram installed.
    u can upgrade ram to 1gig so I would have at least 512ram installed.
    I assume youve reinstalled xp various times to no avail and this means ur cd works also.and if youve downloaded and installed vlc then it not a software issue.It could of been the file type u are trying to play but that wouldnt explain the not responding issue when right clicking on items.so basically it boils down to lack of mem
  • tat4u
    tat4u Apr 12, 2008
    check system information and look at conflicting/sharing
Hi there. I have an Acer Aspire 5600AWLMi, I want to format my laptop and start everything from scratch; reinstalling XP and all the drivers in it. Two problems: 1.Don't have the Acer Recovery...
You need to replace the DVD reader or use an external one, and obtain a windows install CD. Enter your model number on the acer website to get all of the required drivers. Obtain the drivers and put them on a CD before reformatting as you will not have the wifi drive to go get the drivers if you try and get the drivers after you format.
May 11, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer travelmate 345t how to boot from cd
go to BIOS, insert the windows disc and set the CD/DVD drive as the primary boot option. save changes and exit. computer will restart and it should boot from the Windows disc.
Dec 01, 2009 | Acer TravelMate 345T Notebook
Dvd disc is not working
You likely do not have a DVD-Rom. Check the front of the DVD and be sure that it says DVD-ROM on it. If it does not you may consider contacting Acer to upgrade it.
May 19, 2009 | Acer TravelMate 2480 Notebook
Acer Internal DVD RW Drive not working for "written" dvds.
The quality of the writable CD can make a big difference, and maybe run a CD driver cleaner as well.
Another thing to try is to write the CD at a lower speed, not the driver maximum, this can help with less quality CDs as well.
Jules
Apr 23, 2009 | Acer (91.AB264.023) Internal 32x CD-ROM...
Installing XP
Acer computers come with a factory restore partition installed from the factory. The following instructions are direct from Acer's support website:
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
  1. Enter the password created when eRecovery was first started.
  2. Read the on-screen warning and choose Yes.
  3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 18, 2009 | Acer TravelMate 4230 Notebook
Acer travelmate 225x
Hi!
You may buy a recovery cd for your laptop on this site:
http://www.user-guides.co.uk/cddownload/Acer/AcerTravelMate/Acer-TravelMate-225X-Data-Recovery-Boot-Disk-CD-98-XP-57411.html
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Dec 31, 2008 | Acer TravelMate 225X Notebook
New Laptop
The laptop has an eRcovery partition the will restore it to original condition.
Acer eRecovery
At the Acer splash screen, you can press Alt and F10 (at the same time you would press F2 to enter the BIOS) to bring up a DOS style version of eRecovery.
· The unit is able to reload Windows from this mode faster then from CD.
· The password by default is 000000 (6 zeros) and it is displayed when you are asked for the password.
· Users are able to change the password in this mode for eRecovery only.
· The system can recover from the hidden image on the hard drive (PQService partition) or from CD/DVD media.
· It is possible to reload from the factory style CDs/DVD or the snapshots that the Windows version of eRecovery creates.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 14, 2008 | Acer TravelMate 2300 Notebook
CD /DVD burner not identifying the disc
Hi
Type of media settings might be the issue but making a change for standard CD/DVD recording (it affects reading too) Issue can be resolved. Right click on the CD/DVD drive (Usually D or E drive ) click on properties and select and choose the recording option. Click the enable CD recording for this drive option
Click on apply and OK. Try again. You may try after reboot the computer. If issue persist please post so we can think about some alternate solutions.
Good Luck
Jan 24, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer travelmate 2303lc done recovery since then no display on screen
Hi
My cd rom does not seem to be working at all. Lights come on and I can hear how it is reading a disc but when i go into the d drive its just blank. Haven't been using the pc for a while so i dont have the recovery cd anymore? Please help?
Many thanks
Jan 21, 2008 | Acer TravelMate 2303LCi Notebook
Computers & Internet Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
