Question about Frigidaire FGB24S5A Gas Single Oven
Electric power cord
I have a gas stove but the outlet the electric power plugs into is not working is it ok to leave the oven unplugged until I get this fixed? Do i need to turn the gas off also?
    Genius:
  • 1,073 Answers
Good safety move to turn off gas
Posted on Apr 12, 2008
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
I want to reset the oven
Gas or electric? If electric are you sure you have power. Double check the breaker. Turn of and back on. If it pops, you have a wiring problem, the breaker is bad (yes they do wear out). If Gas, make sure you have power to the outlet that serves the stove. If no power the system will not work. If no power to the outlet, again check the circuit breaker for that outlet. If these things don't help check your owner's manual and it's troubleshooting.
Feb 28, 2015 | Ovens
The whole range quit working -
First thing check your breaker. if the breaker is good then unplug the stove and remove the back cover and check the power cord connection where it first connects. Check for any loose connections there. Also if your main power cord is plugged in behind the stove you could check the box for loose connections. Be sure to turn the breaker off first. If you are not sure about handling the electrical outlet then I would call someone who is.
Aug 08, 2011 | Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
SF 3000 EWWO how to light pilot
You can raise the top lid of the stove to light the pilot lights for the top burners.
The oven is controlled by a electric glowbar ignitor.
Make sure the cord is plugged into a electrical outlet.
If it is and the oven does not work the glowbar ignitor must be replaced.
Jan 16, 2010 | Ovens
The digital clock on my Frigidare electric stove is flashing every morning and loses time. Now I told the oven is not staying on.
make sure your power connector is tightly plugged into the outlet- also, check for any signs of possible rodent (no offense!) damage to the wiring! sometimes it's hard to tell if the little devils are lurking about!you may want to unplug the cord and inspect for corrosion. you may want to turn off the breaker for the stove. i assume it's 220 volt. then spray plug with a little WD40. let it dry a bit, and plug it back in, then reset the breaker! if that isn't it, you may have a loose connection, or more inside your stove. in that case, get a pro to check it out!! then do the math- will it cost more to fix it than it will to replace it?? your choice!
good luck!
Dec 05, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
Jun 28, 2008 | Frigidaire FGB24S5A Gas Single Oven
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Frigidaire FGB24S5A Gas Single Oven Logo
55 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
