Ariston washing machine front loader model number BS1400 error message f-05 stops program and wont spin have unscrewed plug at bottom of machine to drain and started fine after that working for a little while but stopped and displayed erroer message again just wondering how to fix it
  • fizzell Apr 11, 2008
    FIXED THE PROBLEM A+++++++++++
    Genius:
  • 1,027 Answers
You could check the pump, open and drain, clear anything out of the pump, next turn off and unplug the mains cable, wait 40 secs and connect mains and turn back on.
Posted on Apr 11, 2008
Why are my clothes dripping wet after the spin cycle I have a ariston front loader avxl129
sounds like the pump could be unable to get the water out after the wash. check the door into the pump, at the bottom front of your machine
Aug 12, 2014 | Ariston Technologies Washing Machines
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
Ariston Washer not running Programme
It sounds as if the brushes in the motor have worn,when the motor stops it wont go through the program,try turning the ddial around to spin to check the motor
Mar 07, 2014 | Washing Machines
How do I unblock the filter and where is the filter located on my Ariston front loader
Remove the lower plastic panel at the front of washer.
The filter is located at the bottom front right.
Unscrew anti-clockwise to remove and clean.
Have some cloths handy as thetre will be some water that will come out.
Jan 05, 2011 | Ariston Technologies Ariston AWD12 Front...
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
My whirlpool front loader has stopped. I've opened, unscrewed and emptied the well/plug at the right hand front bottom of the machine but it still wont work. What should I do next?
hello does it agitate if not it could be the brushes on the motor check another program to see what happens also check the pump inside good luck
shaun
Aug 30, 2009 | Washing Machines
Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
I have an Ariston Magherita 2000 it stops and the dial keeps going around when it gets to the spin. If I then put it back on spin it will not drain the water out. If I empty the machine and then put a...
Yo!
unplug machine from power.
pull the front panel off of the machine its at the bottom, kind of snaps off bottom first then top eases out, anyway becareful as it is pretty fragile plastic.
On right hand side unscrew filter cap - prepare for lots of water that really stinks to pour out. Cap can be a fiddle but does release after unscrewing anti clock wise.
Put fingers in and clear out any blockages you can see, mine was a 1 pence peice and a hair tie. Put back together and it should be ok.
Jan 01, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
290 people viewed this question
Top Washing Machines Experts
