Question about Frigidaire PLRS267ZAB Side by Side Refrigerator
Ice maker constantly runs
Help! Our icemaker is constantly running, all we did was replace the piece that you depress to deliver ice and water, and now it's constantly turning and spitting out ice. Somehow related to the switch on the inside wall, but we didn't replace that. Any ideas?
  • BeckyA6 Apr 11, 2008
    Well from what I can tell, the door itself closes, and pushes the switch closed/in. Once this happens, it just starts churning the axle to shoot out ice, or water if you push the water lever in. Opening the door is the only solution to stop the action, so we've reasoned it's within that switch. How would I go about re-positioning a plastic switch built into the wall of the freezer?
    Can you define or detail what/where the actuator is?
    President:
  • 3,130 Answers
You do not have the actuator postioned correctly on the switch inside the door. The lever has to press up against the switch when you push it. Re-postion the lever.
Posted on Apr 11, 2008
Icemaker runs constantly but never makes enough ice to shot off. Too much water spraying out and melting the ice. What to do? Have run through cleaner cycle several times. Disassembled and cleaned also.
Process of elimination. ... ice thickness sensor (adjust and clean).... water outlet bar with holes that runs down the ice maker plate (make sure all the holes are not clogged and point to correct angle to keep from splashing) check those 1st.. the other steps are more involve if you have refrigeration tools to check refrigerate level, etc.. let me know if this will help 1st
Oct 31, 2013 | Manitowoc SM50 Series Ice Maker
Kenmore elite, can hear water running for ice maker constantly as of yesterday
Well if the water was constantly running into the icemaker, it would be consequently over filling and spilling out through the unit doors onto your floor. The icemaker can be making a whirling sound, which typically means the ejector arm is stuck, most likely due to a failed thermostat or heater in the ice maker itself. If the water valve is stuck and truly is spilling everwhere in your unit, the problem could be caused by a stuck module contact in the ice maker, or a defective water valve. I guess the best thing to do is to isolate the problem, define where exactly you are hearing the noise. Icemaker assembly, or water valve? If the water valve is sticking open, identify which side of the water valve solonoid is making noise, then check the incoming line voltage to the unit with a meter. If there is 110v approximately coming into the valve, replace the ice maker module. If there is no voltage coming into the unit but it remains on, turn off the water supply and replace the valve. Some high end refrigerators use a relay board to activate the water valve.. in this case you'll have to identify the correct relay for the water valve and make sure that its not sticking closed or malfunctioning, if this is truly your problem with the unit.
Dec 24, 2012 | Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
My Frigidaire model Frs26zgg side-by-side doesn't deliver water to the ice maker. What is the likely faulty component?
Note that the temperature in the freezer must be below 10 degrees F for the icemaker to cycle. The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
Jun 01, 2012 | Frigidaire Refrigerators
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool IceMagic Plus not working.
Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
Sep 14, 2009 | Refrigerators
Ice maker
Hi, it sounds like made the inlet tube to the icemaker is frozen up. First thing to check tho is that the water valve to the icemaker is ok. If you take the water line off of the icemaker valve, you should be able to blow through it. If you cannot blew through the inlet line that leads to the icemaker tube, it is plugged with ice. You cn thaw that tube out woth a hair dryer.
If I can help further, please let me know.
Thanks
Vic
May 11, 2009 | Refrigerators
Leaking water on floor only happens when making ice
I wonder if you just notice the noise now because the leak has you more aware? First things first. Lift up the arm on the ice maker (a few hours prior to attempting service) to stop it's operation. You need to roll the unit forward to give you access to the back. You'll see a plastic tube that runs from the bottom compartment (water valve) to the ice maker fill tube. Lower the arm of the ice maker and observe the plastic tube for the location of the leak. The most likely spot would be at the top. A hose clamp can be put on the fill tube after making sure the plastic supply tube is completely inserted into the fill tube. The fill tube is the piece that goes through the rear bulkhead and delivers the water to the icemaker. It may be neccessary to remove the icemaker to thaw out the fill tube using a hair dryer.
Apr 28, 2009 | Refrigerators
Icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Apr 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Frigidaire PLRS267ZAB Side by Side Refrigerator Logo
128 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
