Ariston washing machine error message f-05 - Washing Machines
  • Anonymous Apr 30, 2009
    Mon ariston lavante séchante affiche l'erreur F-05, que faire ?
PUMP WASH BLOCKED WITH A SMALL PIECE OF CLOTHING UNBLOCKED AND MACHINE WORKS FINE
Posted on Apr 11, 2008
mewms_14904
  • 1027 Answers
SOURCE: Ariston washing machine front loader
You could check the pump, open and drain, clear anything out of the pump, next turn off and unplug the mains cable, wait 40 secs and connect mains and turn back on.
blueextc3221
  • 15935 Answers
SOURCE: error message on screen F-05. Cannot open the
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
SOURCE: ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Posted on Jul 11, 2008
mewms_14904
  • 1027 Answers
SOURCE: hi there ariston washing machine
The F-05 error code is an indication the filter is blocked.
SOURCE: I am getting a F 05 error message, what does this mean
The Fault is to do with the on board comp panel I had the same fault, you can either wait till it stops than put it into rinse and spin or take out a service plan for about £85.00 cos the part is very expemsive
Posted on Jan 12, 2009
Error code F-05
F05 - Pressure switch jammed on full
Mar 10, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Fault F 05
This error relates to an object or piece of clothing blocking the pump, Clear it by taking off the inlet hose and releasing the object then all should be ok again
Please rate my help++++Thanks for using FIXYA
Jun 26, 2010 | Ariston Technologies Ariston AWD12 Front...
Error F-05
pulled out filter- golf tee jamming it, now works fine. hotpoint were going to charge me £100 to fix it,as it was something you can't do yourself!!
Oct 24, 2009 | Hotpoint Ariston AW125 Front Load Washer
Error messages on my Ariston AVXD109
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Sep 07, 2008 | Ariston Technologies AWD121WH
Ariston AVXD 129 washing machine displayed F--05
Jul 01, 2008 | Washing Machines
Ariston washing machine front loader model number BS1400 error message f-05 stops program and wont spin have unscrewed plug at bottom of machine to drain and started fine after that working for a little...
Apr 11, 2008 | Washing Machines
Washing Machines Logo
1,207 people viewed this question
Top Washing Machines Experts
