Question about Canon Rebel XT / EOS 350D Digital Camera
Canon XT powers on then dies
Camera suddenly started doing this after approx 18 mths of use.  Tried all the usual troubleshooting--swapped cf cards, batteries, lenses, etc.   Battery is fully charged, camera boots up, but as soon as you depress shutter button to focus/meter it dies and the lcd flashes the battery not charged error icon. Ritz camera told me it was probably a bad battery sensor and they could "probably" fix it for $250 or I could send it to Canon, wait for months, and pay at least double...
ideas? Some have said to just trash it. Any help would be most appreciated.
TKS
  • bibblybot Jun 10, 2008
    Thanks a lot or your reply.  Someday I'll get around to getting it fixed...
  • 36 Answers
Your looking at a bad DC/DC board. Probably about $250 repair. I wouldn't trash it. as it is still a good camera.
Posted on Jun 10, 2008
Says problem with cf card ,but bought new one still the same
CF card sensor malfuction if you purchased a new one then its not the card itself its rather the camera.
please update us what you tried.
Aug 31, 2011 | Canon EOS 400D / EOS Rebel XTi Digital...
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt error messages
error 99 can most times be remedied by taking a standard pencil eraser and carefully cleaning the gold contacts at the back of the lens and the gold maching contacts in the lens opening of the camera... BE CAREFUL not to let eraser crumbs into your camera... keep it clean... reset the battery and give it a whirl.... did it solve the 99 issue?
for the CF it refers to the cf card... here's what I've found on this:
Canon reports that this error code may appear on your digital camera’s LCD (liquid-crystal display) when there is an error reading from or writing to the inserted CF (CompactFlash) card. This error code occurs most often after a user has tried to eject a CF card before the camera has finished writing data to the card.Solution:
Canon suggests that you first try to use a different CF card. If you do not see the error message when you use the new CF card, the first card is probably damaged.
Before you take the next step, drag the files from the CF card to a location on your hard drive to back up the files. Next, you can use Windows’ ScanDisk utility to check the CF card for errors. If you use a Mac, you can use Disk Utility (in Applications\Utilities\) in OS X.
If ScanDisk or Disk Utility fails to resolve the CF card problem, insert the CF card in your camera again. Then format the CF card. On most Canon cameras, you can do this by pressing the Menu button, selecting the Format tab, highlighting Format, selecting Format, and choosing Yes. Make sure you have backed up the data on the card before you do this. Formatting the card will delete the images from the card. After you format the card in your camera, use ScanDisk or Disk Utility to check the CF card again. If you still encounter errors while using ScanDisk or Disk Utility, you should discard the CF card because it is damaged.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.
hope this solves your issues....
let me know
K
May 29, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Canon EOS Digital Rebel 300D will not take pictures
Have you tried to take picture by switching off the autofocus to manual focus in a prperly lit environment?
If it takes a picture, then it has something to do with your auto focus system of your camera. In such a case: try taking out the battery, the memory card etc and switch off the camera and keep it for like that for about 5 minutes. And then insert only the fully charged battery and try again.
If it still gives you a problem and keep trying to focus You will need to take it to the nearest Canon Service centre.
Mar 08, 2009 | Canon Digital Rebel / EOS-300D Digital...
Error 99 in body
Hi
If you have tried different cards, batteries etc. try cleaning the contacts.
1. Get a pencil with a rubber on it.
2. Take of the lens of the camera and clean the little connectors buy using the rubber on the end of the pencil, brush of with a camera brush. Be gentle and try not to brush dust etc into the camera body.
3. Do the same with all the connectors on all the lenses you have. Do the same to the connectors on your battery.
If this has not helped and you have indeed tried new cards and different batteries you will need to take it into a Canon dealer.
Hope that helps.
Jul 07, 2008 | Canon EOS-20D Body only Digital Camera
Error in body
Remove lens, CF card, and battery. Leave in a dry and slightly warm place for 24 hours. Clean lens contacts with a cloth or cue tip and eclipse/alcohol.
If the camera doesn't turn on after this, even without CF card and lens attached, then it needs to go to a Canon service centre. Don't tell them you got it wet, and maybe it will get repaired FOC.
Error99... pls help!!
here is a link for further steps to take on Error 99: Canon info
The article refers to the 30D, but the same troubleshooting will work for your camera too
Feb 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
CF FULL
I just had exactly the same problem with my 20D. I removed and reinserted the battery and it fixed the problem.
Dave
Dec 08, 2007 | Canon Digital Rebel / EOS-300D Digital...
Error 02 problem
Try to use your CF card in another camera. It will let you know if your problem is with the camera or the CF.
Oct 16, 2006 | Canon Digital Rebel / EOS-300D Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
