Hi there ariston washing machine with error message f-05 just wondering how to fix the problem
    Genius:
  • 1,027 Answers
The F-05 error code is an indication the filter is blocked.
Posted on Apr 11, 2008
  • Mark Williams
    Mark Williams Apr 11, 2008
    If the Ariston is like the Hot point, open the front lower panel by prying out on sides at same time, DO NOT FORCE. Open and clear pump. After the pump has been reassembled Un plug the mains wait 40 seconds and plug back in.
How to fix error code f 05 on splendide arwxf129w (na)
F05: Blocked Pump or Pressure Switch stuck on Empty Found
Overhaul CNF (pump connector)
Overhaul Pump Connector
Control Pump Filter
Control Pump Windings
Change Pump
Replace Card
Dado
Jun 07, 2014 | Ariston Technologies Washing Machines
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Fault F 05
This error relates to an object or piece of clothing blocking the pump, Clear it by taking off the inlet hose and releasing the object then all should be ok again
Please rate my help++++Thanks for using FIXYA
Jun 26, 2010 | Ariston Technologies Ariston AWD12 Front...
Error F-05
pulled out filter- golf tee jamming it, now works fine. hotpoint were going to charge me £100 to fix it,as it was something you can't do yourself!!
Oct 24, 2009 | Hotpoint Ariston AW125 Front Load Washer
Error messages on my Ariston AVXD109
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Sep 07, 2008 | Ariston Technologies AWD121WH
Ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Jul 01, 2008 | Washing Machines
Ariston washing machine front loader model number BS1400 error message f-05 stops program and wont spin have unscrewed plug at bottom of machine to drain and started fine after that working for a little...
You could check the pump, open and drain, clear anything out of the pump, next turn off and unplug the mains cable, wait 40 secs and connect mains and turn back on.
Apr 11, 2008 | Washing Machines
Ariston washing machine error message f-05
PUMP WASH BLOCKED WITH A SMALL PIECE OF CLOTHING UNBLOCKED AND MACHINE WORKS FINE
Washing Machines Logo
738 people viewed this question
Top Washing Machines Experts
