Question about Brother HL-2040 Laser Printer
Brother hl 2040 drum unit assembly installation
I just got a brother hl 2040 printer for christmas. Just unpacking it and it tells me to put the drum unit assembly in the printer, but it's not clear how I do that.
  • swedishchef Apr 14, 2008
    Never mind! Finally figured it out!
    swedishchef
I was trying to put it in the wrong side of the printer!
Posted on Apr 14, 2008
Why is the drum error message on after new drum installed and won't print
Hello, you need to reset the Drum Unit life:
After changing a DR2000 drum unit in a Brother HL-2040, the printer's page count needs to be reset. This will turn off the drum warning light on the printer.
Simply open the front cover, and hold the "GO" button until all four LED's are lit. Release the "GO" button and close the front cover.
Jul 28, 2014 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
How do i reset the brother dr350 drum
If you have already replaced the drum - only do steps 1, 2, 3, 7 and 8.
1. Make sure that the printer is turned on and the Drum LED is blinking. Open the front cover of the printer.
2. Press and hold the GO button for about 4 seconds until all the LEDs light up. Once all four LEDs are lit, release the GO button.
3. Pull out the drum unit and toner cartridge assembly.
4. Push down the blue lock lever and take the toner cartridge out of the drum unit.
5. Unpack new drum unit.
6. Put the toner cartrisge firmly into the new drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
7. Put the drum unit and toner cartridge assembly in the printer.
8. Close the front cover.
Jan 29, 2010 | Brother HL-2040 Laser Printer
My printer brother hl-2040 drum light is blinking what is the problem
Time for you to replace the laser drum unit in the printer.
the drum units have a life cycle of about 5000 pages and then need to be replaced. Order a new one from Office Depot and simply swap the units.
Cheers,
Keith
Jan 13, 2010 | Brother HL-2040 Laser Printer
Resetting the counter for Brother HL 2040
wecan reset brother cartage 2ways. when we are filling at that time we can adjust white ringe of cartage. otherway after reffiling . and when we put cartage in side the printer. we should push white and black point and start the printer .then it wi be reset.(it is tech. private methode)
Jun 11, 2009 | Brother HL-2040 Laser Printer
How do I replace the drum on a Brother hl 2040.
I have 'reused' the same drum three times and still prints like a charm.
Open the toner door and pull out the toner/drum assembly. Take the toner off the drum tray. Use a alcohol pad or lint free cloth and wipe the mauve coloured drum to remove the excess lint and toner collected on the drum. Rotate the drum with the white gear and keep cleaning until the whole drum is done.
Put the toner back in the drum tray. Clean the corona wire by sliding the blue tab back and forth 3 or 4 times. Put the toner/drum back into the printer and close the door.
After the printer does the self test the drum light will cone on again so then you need to reset the counters.
Open the door again
Hold the GO button until all 4 lights are lit up
Release the GO button
Close the door
Printer will self test and should extinguish all the trouble lights.
Apr 10, 2009 | Brother HL-2040 Laser Printer
Lost Installation CD for my Brother HL-2040 printer
Where Can I download installation software for Brother HL-2040 printer
Sep 13, 2008 | Brother HL-2040 Laser Printer
Drum Error Light
Yes, the DRUM UNIT has reached the end of its life and must be replaced. You can order a new one from BROTHER,or a local office supply store may have it in stock. It is easy to replace, instructions are included, and when the new one is installed, the DRUM ERROR LIGHT will turn off , and the machine will be ready to use.
Jul 28, 2008 | Brother HL-2040 Laser Printer
Brother hl-2040 printing problem
Could be that there are a mark on the drum itself or some dirt, remove the drum unit and inspect the surface , by rotating the drum , becareful not to touch the drum as it will leave marks on the surface
Apr 25, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
160 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
