Question about Kenwood KDC-MP235 CD Player
Resetting clock how to reset clock on kdc mp532
  • 30 Answers
Try this link for the manual.
http://inform3.kenwoodusa.com/manuals/KDCX590.pdf
Good luck
Leadispenser
Posted on Aug 27, 2008
Resetting clock on truck stereo
The Kenwood KDC-MP335 is an aftermarket car radio that's available for many cars and trucks. The radio unit comes with a built-in digital clock. If your clock is showing the wrong time, all you need to do is enter the radio's clock-setting mode to correct the time and set the clock.------------------------------------------------------------------------
vas 5054a v19
Nov 28, 2012 | Cars & Trucks
How can i take the protection off the radioKenwood (KDC-MP342suburban
You might try disconnecting the memory wire and doing the reset again. If your head unit is not where u can access the wiring harness, you can disconnect the battery. This should clear any settings you have in the radio. Of course it will require resetting the clock, stations, etc...
Apr 20, 2012 | Kenwood KDC-MP2032 CD Player
How do i reset the radio for my XM Sirius? How do i remove KDC-BT742U from dash to reset using tools provided? book is just not clear enough on this.
There is no need to pull the radio from the dash to reset. There is a reset button above the aux in put behind the usb door. You will need a paper clip or a tip of a ball point pen. Once reset you will need to reprogram all of your setting (FM stations, clock) as this will wipe out the memory. To remove the radio from the dash will depend on what kind of car its in. Some (Toyota, Niss.) use the factory brackets to mount in the dash. IF this is the case the dash will need to be disassembled. For the kit installs you will need to remove the trim ring around the outside of the face of the radio. Then the keys will be inserted on each side of the radio releasing the clips then the radio can be slid out.
May 15, 2011 | Kenwood KDC-BT742U
How to reset a clock on a kenwwood kdc-mp2032 car stereo after a new car battery has been installed?
if its a detach face, most of the time there is a reset button on radio itself behind faceplate....push it
Sep 17, 2010 | Car Audio & Video
Can not set clock on Kenwood KDC228 CD Receiver
I spent the better part of an hour trying to figure out how to get the "Clk Adj" screen on the KDC-MP228. Here is the solution (dont waste your time reading the manual, it does not explain this). First, I had screwed up my settings so I did a factory reset (hold in the reset button). Then, you need to turn off Demo Mode (in standby click the Menu button and then use the control button to navigate to "Demo On". Hold the control button in to turn Demo on or off (this is different from all of the other controls in the manual). Now that Demo is off, click Menu button again and use the Control button to navigate through the options, one of which is "Clk Adj". At that point, you can follow the instructions in the manual (Hold in Control button until the clock blinks (approx 2 seconds), then use the FM/AM buttons to change the Hours and the << >> buttons to change the Minutes). Press the Control button again to save your changes. I cannot believe how difficult it was to set the clock on this device, someone should smack the developer who wrote that code.
Mar 08, 2009 | Kenwood KDC-MP228 CD Player
Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
Dec 20, 2008 | Kenwood KDC-MP228 CD Player
My car stereo
In standby hold the menu button down untill menu pops up, the use the up down left right and pushing of the joystick to select clock ans set it :)
Jul 25, 2008 | Kenwood KDC-135 CD Player
Cannot reset the clock
Go here to down load the manual http://www.kenwoodhk.com.hk/english/downloads/index.php
Jun 23, 2007 | Kenwood KDC-MP228 CD Player
Kenwood KDC-MP235 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
