Question about Sunbeam 2351 Legacy Stand Mixer
Batter climbing beaters
We have this mixer for about 12 months without any issues. Just recently, cake batter climbs the beaters until it reaches the mixer body. We checked that the beaters were in the correct holes (red-in-red). This was a boxed Duncan Hines mix. Any ideas? This happened twice in a row.
  • 12 Answers
SOURCE: Oil Leak
There are screws under that metallic ring on the mixer head. Gently remove the metalic ring by pushing down on its edge with a screwdriver. Once the ring is removed the screws are exposed. Tighten each one and then again to make sure they are snug. If this doesn't work, you need a new grease gasket. Good luck.
Posted on Mar 16, 2009
  • 110 Answers
SOURCE: Problems mixing thinner batters thoroughly
Try a higher speed , this should force the batter out using the centrifugal force generated
Posted on Sep 07, 2007
SOURCE: KitchenAid Hand Mixer Beater won't stay in slot
You need a new gear set.  Hard to find however.
Posted on Oct 14, 2007
  • 185 Answers
SOURCE: Mixer beaters clanging together
The beaters might be fixable/replaceable but the bowl not spinning anymore is the more serious of the 2 problems. If this is several years old iit probably is more cost efective/simpler to replace the whole unit.
Good luck Loringh
Posted on Nov 09, 2008
  • 135 Answers
SOURCE: the mixing part of mixer not working motor is fine
Hi. Since I can't tell how much you have taken apart, I'll start from the beginning.
Remove the silver band, remove the top cover. At the top front of the mixer locate the transmission housing. If it's plastic, inspect it carefully for cracks around the screws and the body of this housing. If you find cracks, you have found the cheap plastic part that kitchenaid still installs in new mixers, and the cause of your trouble. They know that it's substandard but don't care enough to place a recall notice on this part. It may not please you to know that their replacement part is METAL like the original part should have been. "For the way it's made"! Indeed!
If you intend to repair the mixer yourself, go to kitchenaid's website, enter your model # and locate the parts list for your mixer. Download the drawings, they will assist you with your project.
Be sure to tell kitchenaid what you think of their cheap plastic part.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Apr 19, 2009
I have a Dash Everyday Stand Mixer 3qt. After mixing , I couldn't remove the bowl from the base. Its stuck. How do I remove it if it has mix in it? I have tried the warm towel around the base of the bowl(...
Take your batter out with a ladle and rubber spatula. Spray the base with WD40. Or stand the base on hot water and soap, just enough to cover the base of the bowl.
Jan 20, 2018 | Food Mixers
Kitchen aid 600 pro making a scraping sound with light load not as bad with heavier load like cake batter. Any ideas what the problem is??
Probably going to need to narrow it down to an area, is it the beater scraping the bowl? Is it in the planetary? Is it in the gearbox? Is it in the armature area? Those are all ideas of where it can be but really hard to offer solutions without you narrowing down the search area.
Dec 16, 2014 | Food Mixers
Beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Apr 14, 2014 | Blakeslee DD-60 Stand Mixer
I have a new kitchenaid mixer and both times i've used it the cake did'nt come out right, it was bland and it fell apart and that never happened before. what did I do wrong?
It could be that your over mixing the batter. It is very easy with a KitchenAid to push a batter too far, and you get too much air, or cream the butter too much into the flour, or press all the oil out of peanut butter. Try using the mixer for only as much to get the matter mixed.
Jul 03, 2012 | KitchenAid Food Mixers
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
I received my mixer as a gift for my birthday in October. The bowl gets stuck and does not release from the base. I have to hit it a number of times with a rubber mallet to get it to release. Also when...
If that is the bowl that came with the machine it is not wrong. What happens from time to time is that the head on the mixer automatically adjusts causing the beater to not operate as it should. To adjust the head on the mixer place a dime at the bottom of the bowl, attatch the beater to the mixer and make as if you are going to start mixing. The beater should JUST touch the dime. If it doesn't touch it at all or is pressing it against the bowl, tilt the head of the mixer up to locate the adjustment screw located inside the shaft. Take a flat head screw driver, turn the screw clockwise (to lower the head) or counter clockwise (to raise the head). Place the beater back on the mixer, turn the machine on and see if it moves the dime moves. Once it is properly adjusted the dime should move ever so slightly.
Nov 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Canot take the beater out of the mixer.when I have mix my my cake I cant get the beater out to clean the beater.
counter top appliance number for kitchen aid is 1-800-541-6390 M-F 8-8 EDT, and Sat 12 -5 p.m.
Oct 21, 2010 | KitchenAid KITCHEN AID 5 Quart Artisan...
The attachment/accessory "screw" fell into my mixer while the beaters were mixing a cake batter. The mixer froze up when it hit the "Screw" and now the unit won't turn on. Did I burn up the motor? Does...
Sounds like a classic case of the gears jumping out of sync. This is an issue that needs to be handled by a repair place or sent back to KitchenAide. The motor on a KitchenAide is very strong and it sounds like when the cap for the accessory fell in it must have somehow gotten jammed, although I really don't see how that would be possible unless there was something else in the mix as well.
Dec 04, 2009 | KitchenAid K45SS Classic Stand Mixer
Oil Leak
Jan 04, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I have the same mixer. Make sure the bowl is firmly latched into the base. also, make sure the bowl didn't get bent in shipping. If the paddle hits at a regular timed interval, it's must likely a problem with the way the bowl seats. As long as you don't hear a loud hit verses just a click, it shouldn't be a problem, just an annoyance. In time, you will probably heat tapping when you use the wire wisk. I am glad I bought mine. I hope you enjoy the difference a good mixer makes.
Jan 03, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Sunbeam 2351 Legacy Stand Mixer Logo
158 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
