New video player - video channel now doesn't work
Please repost with more info
Posted on Apr 11, 2008
Left channels weak and statiky
Maybe your amp is bad? Swich your right and left wires around and see. If the problem moves your player is bad. If it doesn't your amp is bad. Doubt it is the amp though if it is all of your left channels.
Apr 19, 2012 | Dual XD7500 AM/FM/CD Receiver, Motorized...
Monitor says no signal and will not run a dvd
It could be a couple of things. If this monitor is hooked up to a computer, it could be a bad video card. A video card is easily fixed on a desktop, if you're using a laptop you're probably out of luck.
If it's hooked up to a DVD player, check that the cord to the monitor is hooked up properly (make sure the connection goes from the "Video Out" on the player to the "Video In" on the monitor and that all connections are tight, not barely hanging on). If that doesn't work, try a new cable.
This is probably insulting, but also make sure that the monitor is set to the right channel if it's multichannel. For example, if your DVD player is hooked up to HDMI 2, make sure the monitor is set to use HDMI 2 for signal.
If none of these work, it's time to find a tech-happy friend that can inspect everything visually. Hope that helps!
Feb 21, 2012 | Dell Computers & Internet
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
I have a sony xav-622 in a new rv camper. Everything works except the connection to the sony tv on the dvd only plays in black and white. This is connected with a yellow cable with no place to put s...
try cd/dvd cleaning lens kit of your XAV-A1. if still it doesn't work, try opening you XAV-A1 and clean it with a cotton buds with a cleaning solution from the cleaning lens kit. if still it doesn't work, have it change a new lens from a certified technician.
Apr 25, 2011 | Sony XAV-60 Car Video Player
What channel does video player work on?
Depends which input you are using, usually on video 1 or 2. Using the AV button (with your video connected up) switch through the various AV channels then you will see which one is set to your video player (you must have a video in the player on play to detect it working etc). It doesn't matter which input you use, it really is about what you prefer.
May 15, 2010 | RCA 20F424T 20" TV
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Video mode on GE 27GT610
Try hooking up the dvd player and turning it on. Then use the setup and add/erase channel feature to look thru all of the channels. On my older GE tv I found that channel 91 was the correct channel for the video input. I saw the logo for the dvd player on this channel. I just added that channel and now it works. Your channel might be different.
Feb 22, 2009 | GE 27GT616 27" TV
SWITCHING FROM TV MODE TO VIDEO MODE
Hi, If the AV button is not in your remote, then perhaps it is part of the Ch up/down buttons - meaning right after your last programmed Channel would be AV before the first program Channel. Although I have yet to come across such a case, I have worked on units/remotes that have this feature of the AV included in the channel memory. Good luck and kind regards.
Aug 20, 2007 | Broksonic CTGV-5463TCT TV
Can I play the video and a dvd without the remote control?
Your set should have external video and audio imput jacks besides the tuner imput for antenna,you can use the video and audio outputs from the vcr or DVD and conect them to the video and audio imputs in the tv then you can select a channel below 1 or push the switch that says Video/antenna.
Oct 02, 2006 | Samsung CXD2512 25 in. Combo
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
