Question about iLO 2600 Television
Ilo tv stuck on channel
  • Enoble Apr 16, 2008
    my tv is also stuck and the buttons dont work on the remote or on the tv but the remote will turn it on or off
Press your favorite's button then change channels i ran across this problem myself ... so being in favorite's mode keeps you from switching channels
Posted on Apr 24, 2008
ILO 26HD television flat screen won't change channels/stuck on 11
Try doing a channel scan or autoprogram of the tuner again. This should fix the issue.
Nov 11, 2009 | Televison & Video
TV is stuck on one channel and won't change even with remote.
Ii would begin by changing the batteries in the remote. As they lose their power they will control some functions but not others. If that doesn't solve it, get back and we can take additional steps. i want to help.
May 23, 2009 | iLO 3200 32 in. LCD Television
TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
May 16, 2009 | iLO 3200 32 in. LCD Television
Ilo tv is stuck on one (1) channel
call 909-974-2859, they have the parts and tech support for this TV.
Sep 16, 2008 | iLO 3200 32 in. LCD Television
Ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Sep 03, 2008 | iLO 3200 32 in. LCD Television
My tv is stuck at one channel. Which controller board has to be replaced? The Key controller,LCD controller, or what?
I got the same problem, TV stuck on one channel, what I did was, I remove the cable (fron the back) for a minute and then reconnect, work perfect, well, better than try to return the bloody thing.
Good look with your.
D.
May 01, 2008 | iLO 3200 32 in. LCD Television
Stuck on channel
Hello All,
This looks to be a problem either on the IR circuit board or in the microprocessor that controls these features and controls. I would suggest since you have tried to change channels from the TV itself that the problem in the processor is the more likely option. In this case I would say since this would involve a lengthy troubleshooting procedure, That you may have to take your TVs to a qualified TV repair facility for servicing since the procedure may be beyond just replacing a part, and may involve actual electronics troubleshooting. Having owned a shop for some time I can tell you that some items are only repairable at TV shops.
I hope this helps, Thank you, Shuttle83
Jan 05, 2008 | iLO 2600 Television
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
ILO-26HD remote problems
I have the same problem.
Nov 06, 2007 | iLO 2600 Television
My tv is stuck on channel 43
You may have accidentally pressed 'Favorite' on the remote. Try pressing 'Favorite' to unlock the controls.
Jul 24, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
59 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
