Vibe CBR12 Car Subwoofer Logo
Posted on Jun 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No audio subwoofer just pulses and indicator light flashes
Worked fine then the next time i come to turn it on it just pulses with no audio checked fuses and 12v line with multimeter not sure what to do?
Anonymous
Level 3:
Master:
  • Master 383 Answers
  • Posted on Jun 11, 2010
Anonymous
Master
Level 3:
Master:
Answers
383
Questions
Helped
80900
Points
1103
Push it in a little bit to see if its blown
I have a sapphire subwoofer model PS 3 b. When
theres no input signal. the green indicates only when it detects incoming. check your amplifier.
Wont move battery light pulses and battery indicator shows full cherge
you may have got some of the electrics wet, if so it should dry and be fine, if not then we need to know how many light segments are lit, and how many flashes.
2answers
Why standby light flashing and system not turn ?!
This indicates a load in the system, check speaker wires on the back for any shorts, next! suspect a problem in one of the audio output chips if the speaker wires are okay, at this stage I recommend a service technician
Blue light on top flashing???not powering subwoofers.. was working fine.( blue light stayed on.) When I noticed it I shut the system down immediatley!!! Have'nt turned sytem back on since. What should I do...
You amp went into protect mode from an abnormal condition. Were you hammering on this amp when that started? I might suggest letting up on it a bit if so. Also check your wiring. Make sure all are insulated well and fully connected. It cut the noise off because if it would have continued it would have blown your amp. Make sure the fuse is good as well. Perhaps it is getting weak. Turn things down and turn the amp on. Give it a chance to cool for a bit first and then turn things down and turn it on. Everything a go? Then turn it up a bit then. My guess is it was getting worked a bit to hard and went into protect mode. Give the amp a rest from time to time. Good luck.
1helpful
2answers
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
2004 dodge caravan. Engine light is pulsing 10 times
i would disconnect the battery terminals for 2 min then reconnect see if its fixed
Sub is unresponsive
unhook the orange wire and also try the remote wire, rerun that too the amp
4helpful
2answers
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
2answers
Can't get sound from the wireless subwoofer
There are 2 things you can try, first ensure that the digital transmitter is fully inserted into the slot of the main unit. Secondly do you have any other wireless devices near such as cordless phone or wireless network equipment? See page 5 of the installation manual as per this picture.......
Top Vibe Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Vibe Car Audio and Video Expert? Answer questions, earn points and help others
