Back to:
Tags:
Fedders A7DH45B2A Dehumidifier
Humidifier is freezing up (by 4 users)
posted by steck on Apr 10, 2008
Our M7DH45B2A humidifier is now freezing up. We purchased it 14 mos. ago and it has worked FINE. Now it freezes up and it's frustrating. The room temp is the same in our basement as it always has been. 66 degrees. I was told that some models will not work properly in temps. less that 65 degrees. But the room temp here HAS NOT changed since we first used the Dehumidifier.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Nov 11, 2008
Daveschevy2 hit the nail on the head. I had the exact same freezing up problem. I opened up the case and found the temperature sensor rusted and just hanging by its wire. I used my Dremel tool to clean the rust then I used a piece of wire to tie it back onto the coil in the correct position. Thank you for the fix.
Comment by daveschevy2, posted on Jun 27, 2008
I have the same dehumidifier and it does the same thing. but I was able to fix mine. It was not low on refridgerant. There is a temp. sensor clamped to the evaporater coil with a thin metal clip. The clip rusted out and the sensor fell out of position. I used a small stainless steel hose clamp and clamped the sensor back into position. It now works fine
Comment by Guest, posted on Jun 04, 2008
I have the same freeze-up problem...I assume it must be a small leak or all the coolant would be lost. Is this a problem that can be fixed by trying to patch the leak?
Best Solution
Helpful (85)
daveschevy2
Rank:Apprentice Apprentice
Rating: 85%, 2 votes
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Humidifier is freezing up:
I don't want to Accept this solution
Solution #2
posted on Apr 10, 2008
Not Rated (0)
fixum1
Rank:Guru Guru
Rating: 87%, 545 votes
you have a sealed system leak, some have a 1 year sealed system warranty some have a 5 year warranty parts only labor is only 1 year
Thank You!
Can you Help with these Dehumidifiers problems?
Is it cheaper to have the leak repaired or just buy...
Runs but will not collect water, then Full light...
Unit fan runs fine except the compressor won't come on....
we need a water tank for our fedders A7DH45B2A
The water tank vibrates and causes noise. might be...
Loading problems.
Repair Service
Find Dehumidifier Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
