Question about HP Pavilion F1703 17" LCD Monitor
White horizontal lines of static on monitor
White lines of static esp. when downloading or clicking buttons on pages. I am using EV730 gateway monitor. My operating system is: Ubuntu 8.04 (linux). Thankyou very much..........Rich
  • 236 Answers
Can you try reducing your monitor refresh rate to a lower frequency, or the lowest frequency.
Posted on Apr 10, 2008
Gateway modem
1) FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static electricity BEFORE reaching inside your computer, and BEFORE taking any new parts out of their anti-static bags, or cartons.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
2) Open the computer case;
Click on User Guides in the Gateway link above.
In the list click on -
8513028 - Gateway Hardware Reference Guide
[ This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up ]
(Note* First page is Black, and blank. Second page is blank, and White)
Hover your mouse cursor on the bottom/middle of the page. The ghosted out navigation guide will appear. Click on the PDF icon all the way to the Right. (Show Adobe Reader Toolbar)
Use the Plus ( + ) icon at the top of the PDF file, to increase the view size.
Click on the Minus ( - ) icon to decrease the view size.
Use the Down Arrow at the top of the PDF file to go to Page 41.
(PDF reader page number. Actual manual page is 35)
Loosen the two Thumbscrews, pull back on the formed fingerpull, and remove the left Side Panel. (Pulls back so far, then tilts out to remove)
[I find it best to remove all cables beforehand, then put a soft cloth on the table, and lay the computer on it's side. Much easier to access hardware components on the motherboard ]
Going back to the main support page, click on Components.
In the list, and under the bold black subheading - Motherboards,
click on -
4006273R - MSI Nvidia MCP73PV Motherboard
The two long White slots shown at the bottom of the motherboard, are PCI expansion slots.
An Ethernet card can be plugged in here.
(PCI Ethernet Card example, {10/100/1000},
Notice above the two long white PCI slots, that there is a longer Black expansion slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
The small White slot above it is a PCI-Express x1 slot.
It can also be used for an Ethernet Card.
A PCI-Express x1 Ethernet Card,
A closer look at a;
1) PCI expansion slot,
2) PCI-Express x1 expansion slot,
[ Just for reference a PCI-Express x16 expansion slot,
When removing a PCI-Express graphics card, the tab lock on the end is gently depressed ]
Adding or replacing an expansion card, starts at the bottom of Page 54. (PDF file page. Actual manual page is 48)
The metal slot covers at the back of the computer case metal frame, are Expansion Slot Covers.
Remove the one covering the slot you need, by removing it's Philips head screw.
Note that the slots in the metal frame for the expansion cards, does not line up with the expansion slots on the motherboard. They are one over.
Insert the Ethernet Card straight down in the expansion slot, lining up the Locating Notches at the bottom of the Ethernet Card, with the Locating Lugs down in the bottom of the expansion slot.
You also have to slide the 'tang' at the bottom of the Ethernet Card's metal bracket, down into a space in-between the outside metal framework of the computer case.
Plus line up the bracket's locating hole, (half-moon?), with a short dowel in the metal framework.
All of the above will become apparent once you start to install the Ethernet Card.
One last procedure is to Physically push down on each Ram Memory module ('Stick'), and also make sure the Locks at each end, are up, and in place.
Ram Memory gets bumped real easy. Better to check before going on. (Visual inspection will Not do. You have to physically check)
Card plugged in, and fastened down, close the computer case.
Reattach all cables if you disconnected them.
Plug the computer back into power.
Plug the Ethernet cable into the Ethernet Card.
WAIT 1 minute, turn the computer on.
For additional questions please post in a Comment.
Oct 18, 2012 | Gateway DX4640-UBC01A PC Desktop
How to change cmos battery in gateway mx6214
its a pretty simple procedure. open your computer up and locate the battery use a non-magnetic flat-head screwdriver to pop it out and put the new battery in (sidenote:always unplug everything connected to the computer and press the power button so no electricity is flowing.)
Apr 02, 2011 | Computers & Internet
Where is the headphone jack for the gateway EV730
You have to connect your headphones at the line out of the audio card at your desktop. It's the green jack with 3.5mm diameter at the back of your case. If the place that you have the desktop is not conventional for plug and unplug the headphones, I suggest you using an extender like this one. In case you use a speaker set there must be a headphones output either on one of the speakers or at the control unit.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct fixya link:
Sep 04, 2010 | Gateway EV 730 17 in.CRT Conventional...
I have lines that appear on the monitor that started as a speck, then a line and now it appears extending from the bottom of the screen to the top. What is the cause of this and how can it be corrected?
Well, I have a 24 in Gateway. I unplugged everything from the screen, held the power button for 30 seconds, and plug everything back in. It worked again, apparently the problem was caused by a build up of static electricity and pushing the power button cleared out the static. Hope this helps.
Jun 16, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Lines on screen
This happened to me once too. It is something with the monitor, which needs to be cleaned inside, that is all. Just take it to a mechanical store and they will fix it
Aug 09, 2009 | Gateway 500 CS PC Desktop
CRT EV730 Monitor Just went out won't power won't do any thing
Check the color of the pluggie that goes into the back of your monitor, it is most likely either blue or white. Find a friend who has the same color plug and borrow their monitor for a few minutes. If theirs works; your monitor has **** out. If theirs does not work then your video card (on-board or add-on card) has **** out and you'll have to have a new card added to your system.
Jun 22, 2009 | AOC CT720G 17" CRT Monitor
Static on Screen
Is this an LCD type of monitor or CRT? either case, there's a problem with the horizontal IC. My best solution for this case is to have the unit serviced by an authorized personnel as meddling with the internal circuits of the monitor is dangerous.. Have them estimate the price for repair, if it costs too much... better buy a new one.
For CRT type of monitors: try degaussing, this feature can be found on the OSD (On Screen Display). This can be accessed by pressing Menu on the monitor buttons.
Hope this helps!
Feb 21, 2009 | HP Compaq WF1907 Monitor
A big white vertical static band appears as soon a i turn on the power
Some of the transistors or the connection to the panel inside the monitor are damaged. There is no absolute fix for this problem.
You can try pushing on the bezel (NOT ON THE SCREEN) of the monitor at the edge of the screen directly at the lines and you may be able to push the connection back together well enough that the line goes away, but usually in desktop monitors the bezel is too rigid to allow you to put any pressure on the connections at the back of the LCD panel.
Mar 30, 2008 | Sony SDM-P234/B 23" LCD Monitor
Gateway EV730
Hello Jahodi
Happy Holidays
WHat kind of lines has it? from any program or it is directly from your monitor? may be is your monitor that has problems with horizontal lines, this happend sometimes.
try changing to the refresh rate to 75, or the size of the screen. to 1024 x 768
Dec 21, 2007 | Gateway 500 CS PC Desktop
Polyview V372 lcd monitor
unplug it, and put the plug back in, i have the horizontal white lines before, and it was static build up in the plug just pulling it out and putting it back should fix it
Nov 06, 2007 | Xerox XG-91D 19" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
453 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
